EFIS compatible with FLARM
Old June 4th 20, 09:47 PM posted to rec.aviation.soaring
Default EFIS compatible with FLARM
I mentioned this subject (EFIS compatible with FLARM) to a friend
He has his own company Midwest Panel Builders www.midwestpanels.com
He just emailed this to me. I would like to pass this along to anyone interested.
"You mentioned FLARM to me in the glider community. I put together an EFIS system that will work with FLARM
"MGL iEFIS MX1: $2,655
Weight: 2lbs
Current draw: .6 amps
It has airspeed, altitude, attitude, heading, can work with many COM radios (and new ones are cheap), and can take FLARM inputs. Lighter than an airspeed indicator and altimeter and has a low enough current draw to run for 24 hours on a standard 12AH lead acid battery. Throw a lithium battery in and now you have an even lighter solution. GPS Built-In too.
Cannot be used on certified aircraft however."
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 05:13 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 09:57 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 05:31 AM
Definitely not Oshkosh compatible john smith Piloting 4 December 22nd 06 06:09 AM
WinPilot-compatible GPS devices Ted Wagner Soaring 21 January 12th 04 11:27 AM
