FS Cambridge L-NAV Variometer
Old June 5th 20, 08:57 AM posted to rec.aviation.soaring
Paul[_10_]
Default FS Cambridge L-NAV Variometer
One L-NAV
One Vario
One GPS-NAV display
Two GPS20
They came with a glider I bought 4 years ago, and were working when removed recently for a panel upgrade. Includes a box of wiring: everything that hooked them into my glider, plus stuff that I've never used. The two guys I bought the glider from each had their own GPS units, that's also why there's colored tape on the boxes and connectors - they'd each plug their own unit in before flying.
I'm pretty sure the GPSs are model GPS20, not the GPS10 or GPS25, based on the description and dimensions in the manual (http://www.bas.uk.net/docs/GPSNAV5.PDF), but I might be wrong about that. I only used one of them, and it's worked fine. The original owners said both worked, but also that they have the "date problem", which is an issue if you want to use them as certified recorders, they work fine for navigation. Search Cambridge L-NAV date problem" if you want more information on that.
Contact info, pictures, and video - all from May 2020 he
https://photos.app.goo.gl/AKbEd5bQduFuHTNFA
Thinking $400, including shipping in the USA.
Cambridge CPT 505 Variometer John Foster Soaring 8 July 28th 19 11:40 PM
Cambridge 20 GPS/NAV & LNAV with 57mm variometer for sale Kent Soaring 3 September 21st 09 04:21 AM
Cambridge Audio Variometer for sale Spam Soaring 0 September 5th 09 02:15 AM
FS Cambridge Mk IV Variometer and Oxygen Regulator [email protected] Soaring 1 January 20th 09 05:07 AM
Cambridge variometer f.blair Soaring 2 January 14th 05 04:44 AM
