Getting used to the Arrow...and I like it...a lot!
Old April 13th 05, 07:48 PM
Jack Allison
Default Getting used to the Arrow...and I like it...a lot!
To date I have a whopping 8 hours in the Arrow. The last 2.9 were by
far the most fun since the two flights involved maneuvers and landings
(lots of landings). The more I get to fly N2104T, the more I like it.
Things are becoming more and more comfortable and familiar. Still have
lots to learn but I'm having fun. Hopefully, I'll be able to get some
solo time soon, maybe in a week or so. Solo will be rather interesting
since I haven't done so since last August, right before my FBO melted down.
Overall impressions to date:
- Float down the runway? Nope, it ain't a C-172. Much harder to float
down the runway in an Arrow. Easier to contact said runway with carrier
landing force though.
- Pull the power back and you can drop like a streamlined manhole cover
if you need to. I'll bet forward slips are fun (have yet to try them).
- Things are busier in the pattern with the addition of gear, more
speeds to remember, CS prop, extra mantras you chant (My personal
favorite is "Pump(s), Red(s), Blue(s), Greens" on short final for the
last check of boost pump on, mixture full rich, prop full forward, and 3
in the green).
- The ground moves by faster now. Not that I'm doing a whole lot of
looking down but it takes less time flying to/from the practice area.
- 200 HP at sea level on a cool evening and lightly loaded is fun.
- I'd almost forgotten how much better I like fuel injection. Have
experienced lots of carb ice situations in the Archer during evening
instrument lessons. One less thing to worry about.
- When working on a Complex endorsement, your CFI has a whole new set of
options for messing with you. "What, no 3-green...what ya gonna do
there Mr. Pilot?".
- Engine out scenarios work way better when you pull the prop back.
Very good object lesson in drag reduction.
- Would rather have airspeed in knots...though, I learned that you can
setup the GNS-430 for MPH...but...why? :-)
- Stalls are rather unimpressive, similar to the Archer.
Buffet...yawn...that's it. A good thing.
- Wing on the bottom vs. wing on the top: Really doesn't matter. I'm
just happy to own something with a wing. :-)
- It's really cool to (honestly) say "Yes it is" when asked "Is that
your Arrow?". The closest I was able to do so in the past was answer
"Yes, it's ours by the hour" when asked about newer model rentals I
happed to be flying in.
Jack Allison
PP-ASEL-IA Student
Student Arrow Owner, N2104T
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Old April 13th 05, 08:39 PM
Jim Burns
Second only to a new student who comes back from his first flight full of
enthusiasum with an ear to ear grin is the new owner who has just came back
from one of his first "comfortable" flights in his new airplane.
Are you having fun or what Jack??!!
there Mr. Pilot?".
You're going to relax and get the checklist out. Don't try to memorize what
to do for this one. If you memorize it for one plane, you'll screw
something up in another plane. This one isn't an emergency... it's a
situation... it just becomes an emergency if you are actually forced to put
it down with the wheels in the wells.
Keep having fun!
Old April 13th 05, 09:05 PM
Jay Honeck
A forward slip in our Pathfinder is like riding a peregrine falcon in a
vertical dive. The world gets big, really, really fast.
Ain't it? I remember my first flight in our Pathfinder, with a 145 pound
CFI, light on fuel, in the winter. Yee ha! All I could see was sky.
There is simply no substitute for horsepower.
First time I've ever heard of a Cherokee icing. It's never happened to me,
even in the damp, cold Midwest. (Cessnas are another story...)
- It's really cool to (honestly) say "Yes it is" when asked "Is that your
Arrow?".
Pride of ownership is worth all the headaches and hassles. (Just keep
repeating that at annual time, over and over...)
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old April 14th 05, 12:46 AM
Jack Allison
Hmmm, sounds like I need to try a few the next time out with my instructor.
Yep, I was surprised as well but on several instrument lessons at night,
I'd be flying a DME arc or a hold and all of a sudden realize that I'm
holding some back pressure to maintain altitude...look at the tach and
notice that we've lost maybe 150 RPM. Apply carb heat, power drops then
vrooommm, we're back at the initial power setting.
I'll try to remember this one.
Jack Allison
PP-ASEL-IA Student
- Leonardo Da Vinci
Old April 15th 05, 04:28 PM
Dave Butler
You'll probably never need to know about it unless you fly in IMC. Try flying at
holding or approach airspeed inside a cloud for a while in a carbureted Cherokee
without the c-heat on.
Old April 14th 05, 12:58 AM
Javier Henderson
Jack Allison writes:
So the speeds look bigger.
-jav
Old April 14th 05, 02:47 AM
john smith
What speeds are you using?
Downwind:
Base:
Final:
Short Final:
Over the Threshhold:
Theory question: What is the minimum Indicated Airspeed for a slip?
Is there a difference between right and left slips?
in the green).
Remember that one of the greatest causes of gear up accidents is a go
around. The pilot brings the gear up reenters the pattern and forgets to
put it back down.
Jack, have you downloaded the PA28 review from the AOPA Aviation Safety
Institute website?
Which engine priming system does your aircraft have?
Old April 14th 05, 09:33 AM
Cockpit Colin
Downwind:
Base:
Final:
Short Final:
Something that's always worked for me ...
Take Vso (bottom of white arc) - reduce it by 5% for every 10% under MAUW
then multiply it by ...
1.3 for over the fence speed
1.4 for Base
1.5 for downwind
Works for all aircraft I've flown (although I add a bit in C172 - Vso
(adjusted) can be as low as 28 knots - so at 28 * 1.3 (approx 37) it still
hasn't stalled, but controls are getting pretty mushy (any people who bring
them over the fence at 65 to 70 wonder why they float!)
Old April 15th 05, 10:14 PM
john smith
One of aviation's Rules of Thumb...
an approximate best approach speed is found halfway between the top and
bottom of the white arc.
1.4 for Base
1.5 for downwind
Old April 17th 05, 11:07 AM
Cockpit Colin
"john smith" wrote in message
It's certainly never going to kill you, but it doesn't make any adjustments
for being light (say 1 pilot, and minimal fuel) - which can make approx 13
knots difference to the ideal approach speed in the Arrow (and 10 knots
difference to your dirty stall speed).
Since I started calculating approach speeds I've been amazed at how the
consistancy of my landings has improved - even 5 knots makes a difference.
Fun weekend buying an Arrow (long) Jack Allison Owning 44 April 20th 05 12:29 PM
Fun weekend buying an Arrow (long) Jack Allison Piloting 45 April 20th 05 12:29 PM
Ongoing Arrow alternator/charging problem Chuck Owning 6 December 22nd 04 01:18 AM
Remember the Arrow onsitewelding Piloting 5 August 28th 04 06:47 PM
CF-105 AVRO Arrow etc. Ed Majden Military Aviation 4 February 22nd 04 07:00 PM
