Fokker C.X
Old November 21st 19, 03:03 PM posted to alt.binaries.pictures.aviation
Miloch
Default Fokker C.X
https://en.wikipedia.org/wiki/Fokker_C.X
The Fokker C.X was a Dutch biplane scout and light bomber designed in 1933. It
had a crew of two (a pilot and an observer).
The Fokker C.X was originally designed for the Royal Dutch East Indies Army, in
order to replace the Fokker C.V. Like all Fokker aircraft of that time, it was
of mixed construction, with wooden wing structures and a welded steel tube frame
covered with aluminium plates at the front of the aircraft and with fabric at
the rear. The prototype was built in 1934 with a Rolls-Royce Kestrel V engine.
The East Indies Army ordered 13 C.Xs, but they were soon replaced in the
scout/light bomber role by the American Martin B-10s. Until the Japanese attack
on the Dutch East Indies in 1941, the C.X remained in use as a trainer and
target tug.
The Dutch Air Force ordered 16 C.Xs, and later four more with Kestrel IIS
engines. These four were later re-equipped with Kestrel V engines; the Kestrel
IIS proved not very reliable.
Two C.Xs were delivered to the Spanish Republic, and four more to Finland. The
Finns also license-produced 35 C.Xs until 1942. These C.Xs were equipped with
Bristol Pegasus XII engines.
Airspeed Ltd. in Great Britain got a license to build C.Xs for the British
market as the Airspeed AS.22, but no orders were received.
Role
Light reconnaissance, bomber aircraft
National origin
Netherlands
Manufacturer
Fokker
Introduction
1933
Primary users
Royal Netherlands Air Force
Finnish Air Force
Republican Spanish Air Force
During the German attack on the Netherlands in May 1940, the C.Xs served in
their intended role as scouts and light bombers. The tactic of "hugging the
ground" allowed the C.Xs to achieve some success. Two C.Xs and their crews
escaped to France after the Dutch surrender.
The Finnish C.Xs served with distinction in the Winter War, the Continuation War
and the Lapland War. The C.X was the most important short-range reconnaissance
aircraft and dive bomber of the Finnish Air Force at the outbreak of the Winter
War. There were 29 of them in combat units, the "Frans-Kalle" was slow but
possessed a robust airframe, making it a useful asset. the maximum dive speed
was 540 km/h, which enabled it to break away from the Soviet I-153 and I-16
fighters. As hostilities continued, losses began to mount. During the Winter War
8 FKs were lost. The last of the seven Finnish C.Xs that survived the war
crashed in 1958. The craft, designated FK-111, served as a target-towing craft
in the Finnish Air Force. The plane crashed into a forest on 21 January 1958,
killing the pilot (Second Lieutenant Aimo Allinen) and the winch-operator (2nd
Ltn Antti Kukkonen).
Specifications (Fokker C.X)
General characteristics
Crew: Two
Length: 9.2 m (30 ft 2 in) (Dutch) or 9.1 m (30 ft) (Finnish)
Upper wingspan: 12.00 m (39 ft 4 in)
Lower wingspan: 10.50 m (34 ft 5 in)
Height: 3.30 m (10 ft 10 in)
Wing area: 31.5 m2 (339 sq ft)
Empty weight: 1,400 kg (3,086 lb)
Gross weight: 2,250 kg (4,960 lb) (Dutch) or 2,500 kg (5,500 lb) (Finnish).
Max takeoff weight: 2,900 kg (6,393 lb)
Powerplant: 1 × Rolls-Royce Kestrel liquid-cooled V-12 (Dutch), 485 kW (650 hp)
or 850 hp (630 kW) Bristol Pegasus XII nine-cylinder air cooled radial (Finnish)
Propellers: 2-bladed
Performance
Maximum speed: 320 km/h (200 mph, 170 kn) (Dutch) or 340 km/h (210 mph)
(Finnish).
Range: 830 km (520 mi, 450 nmi) (Dutch) or 840 km (520 mi) (Finnish).
Service ceiling: 8,300 m (27,200 ft) (Dutch) or 8,400 m (27,600 ft) (Finnish).
Rate of climb: 8.3 m/s (1,630 ft/min)
Armament
Guns: 2 × 7.9 mm (0.31 in) machine guns fixed in top of front fuselage with a
third manually aimed from rear cockpit in Dutch aircraft. Finnish aircraft used
same number of 7.62 mm (0.30 in) L-33/34 in same locations.
Bombs: 2 × 175 kg (385 lb) or 4 × 100 kg (220 lb) bombs on underwing racks
Fokker D.VII pics [1/8] - Airworthy Fokker D.VII reproduction incorporating an original engine and parts.jpg (1/1) Miloch Aviation Photos 0 September 26th 19 02:54 PM
Fokker F.VII pics 4 [1/5] - Swissair Fokker F.VIIb-3 m (CH-192) in Kassala, Sudan, February 1934.jpg (1/1) Miloch Aviation Photos 0 January 27th 19 03:35 PM
Fokker C.IV pics 2 [10/12] - Mr. B. Stephan, general manager of the Fokker works, standing by a Fokker biplane with Napier Lion engine.jpg (1/1) Miloch Aviation Photos 0 September 20th 17 03:24 PM
Fokker C.IV pics 2 [09/12] - Major Zanni and his engineer, Mr. Beltrame, while between them is Mijnheer Anthony Fokker.jpg (1/1) Miloch Aviation Photos 0 September 20th 17 03:24 PM
Fokker C.IV pics 1 [02/12] - A batch of Fokker machines with Napier Lion engines in the Fokker factory at Amsterdam.jpg (1/1) Miloch Aviation Photos 0 September 20th 17 03:22 PM
