https://newatlas.com/drones/ab5-jetq...powered-drone/
While propeller planes certainly do have their place, sometimes the extra speed and thrust of a jet engine is what's really needed. Dallas, Texas-based FusionFlight has applied that sort of thinking to quadcopter-style drones, resulting in the AB5 JetQuad. According to the company, the AB5 is "the world’s smallest and most powerful jet-powered drone with vertical take-off and landing [VTOL] capabilities." Instead of the usual four electric motors and propellers, the current prototype has four diesel-powered microturbine jet engines which produce a combined 200 horsepower (149 kW) at full throttle. Thanks to a proprietary vectoring system known as the H-Configuration, the thrust from these engines can be directed either to move the drone vertically when taking off and landing, or horizontally while in flight. The production version of the aircraft will reportedly have a top speed of over 300 mph (483 km/h), with one fill of its 5-gallon (19-l) fuel tank being good for 30 minutes of hovering or 15 minutes of cruising. Down the road, the addition of components such as afterburners could boost its speed considerably. It will carry a maximum payload of 40 lb (18 kg), with cargo being either attached to the drone itself or dangled on a line underneath – the company states that the cargo won't be blasted by the engines in the latter configuration, as the thrust is never vectored straight below the AB5. The drone itself weighs a claimed 50 lb (23 kg), with a full tank of fuel adding another 40 lb. FusionFlight CEO Alexander Taits tells us that the AB5 may be on the market by 2021, priced somewhere between US$200,000 and $250,000 depending on the model. Potential buyers are likely to be putting a premium on speed and power. "The jet engines can put out significantly more power then electrically-driven propellers and also allow the vehicle to travel at much higher speeds," says Taits. "Diesel fuel, on a pound-for-pound basis, stores 40 times more energy then any lithium-type battery and also will take minutes to refuel instead of the hours it takes to recharge an electrical drone." * |
Miloch wrote in
People can now order over-the-counter medication and snacks to be delivered to their homes by DRONE... - A Wing delivery drone lowers a cord onto which the package is hooked and then lifted back up to the drone.jpg ... | Miloch | Aviation Photos | 1 | October 19th 19 10:39 AM |
The US Army is making a laser-powered drone that can fly indefinitely | Larry Dighera | Piloting | 0 | September 4th 18 10:59 AM |
Boeing wins bid to build the Navy’s carrier-launched tanker drone - Boeing refuel drone MQ-25 Stingray (2).jpg | Miloch | Aviation Photos | 0 | September 1st 18 04:30 AM |
North Korean Drone Found in South Korea Was Spying on American Missile Defense System - NKorean drone.jpg | Miloch | Aviation Photos | 0 | June 13th 17 03:36 PM |
Facebook's massive solar-powered drone takes its first flight | Larry Dighera | Piloting | 1 | July 25th 16 03:25 AM |
