Cleaning seat belt materials
Old July 8th 20, 05:13 AM posted to rec.aviation.soaring
AS
Default Cleaning seat belt materials
Hi all - does anyone have any experience with cleaning seat belt webbing? I can remove the buckles from the webbing and was wondering if this material can be washed using a mild detergent like Woollite or similar.
Uli
'AS'
Old July 9th 20, 11:08 PM posted to rec.aviation.soaring
KyleCharles
I have washed many skydiving rigs. I use a tub of lukewarm (not hot) water and a little bit of Woolite to wash a harness/container system. Use a soft bristle brush, rinse very well and hang dry in a place where it will dry quickly. Woolite is the standard for jobs like this. This is how every rigger I have known does it.
FWIW,
Kyle
Old July 10th 20, 12:19 AM posted to rec.aviation.soaring
AS
FWIW,
Kyle
Thanks, Kyle! I will try that.
Uli
'AS'
Old July 10th 20, 02:39 AM posted to rec.aviation.soaring
Bob Kuykendall
You probably already know this, but just to be on the safe side: Avoid acidic cleaning agents like bleach.
Also be careful to avoid situations that might expose the webbing to battery acid. It's very bad for nylon.
As others suggested, I wash my climbing ropes and other nylon soft gear with woolite. Were I to need to wash my seat belt webbing, that's how I'd do it.
https://www.cmcpro.com/what-happens-...ts-on-my-rope/
--Bob K.
Old July 10th 20, 02:42 PM posted to rec.aviation.soaring
Interesting web page. They said they ran strength tests after exposure to a nice assortment of stuff. But I don't see the test results?
(I do like the design of the rope pull tester though ;-)
Seat Belt Re-Webbing vontresc Soaring 4 March 25th 14 07:16 AM
Seat belt clip Fred[_4_] Soaring 2 June 23rd 08 05:10 PM
Seat belt tags Stephen Stilkey Owning 28 March 15th 04 04:29 PM
Seat Belt Extenders M.E. Borner Owning 4 October 3rd 03 01:55 PM
Seat Belt Age? BD5ER Home Built 2 July 7th 03 12:10 AM
