Ventus CM starting problems
Old July 12th 20, 11:13 PM posted to rec.aviation.soaring
Default Ventus CM starting problems
For those who own Ventus Cm: have you ever measured the voltage on the starter when it is running?. Mine, with fully charged battery, while electric starter is running, voltage on battery fall out to 10volts, and on starter I measured only 6 or 6.5 volts. I have a voltage lost of aprox 2 volts over the positive wire and 1.5 over the negative one. Is that normal? I have starting troubles sometimes and i think it is because of it. What can you tell me about it?
Old July 13th 20, 04:09 AM posted to rec.aviation.soaring
SoaringXCellence
Lucas,
When was the last time the power cables to the starter were replaced? Sometimes the cables start to have strands break inside the insulation due to flexing and vibration. This reduces the effective cross-section and increases the resistance.
Have you checked the cable fittings where they attach to the solenoid and the starter? If they are loose it can lead to arcing and overheating, again increasing resistance. If they are corroded they may not make good contact with the bolts where they mount to the starter or relay.
That's where I would start looking.
Mike Bamberg
Old July 13th 20, 10:55 PM posted to rec.aviation.soaring
El lunes, 13 de julio de 2020, 0:09:49 (UTC-3), SoaringXCellence escribió:
Lucas,
Mike Bamberg
Hi Mike! Thanks for your response. I´ve never changed the cables. I own the Ventus CM since 2017, don´t know if they were replaced before that (it was built in 1991)
What I am doing now is installing adicional cables, so I will duplicate the section. Te first test I did, I recover 1.5volt measured on the starter, so now, instead of 6volts, I have 7.5 volts on the starter. It seems to run faster... But I would like to know if this drop of voltage is normal or the problem is only mine.
Old July 13th 20, 11:37 PM posted to rec.aviation.soaring
Dave Nadler
On Sunday, July 12, 2020 at 6:13:50 PM UTC-4, wrote:
...I have a voltage lost of aprox 2 volts over the positive wire
That's a ENORMOUS voltage drop!
I never owned one of these beasts, but...
1) If you let it crank (or try) for a brief period,
the area dropping the voltage will heat up.
First expose as many as possible cables, connection points,
and relays. Then crank for a bit, and feel for hot spots.
You might be able to find problem areas quickly this way...
2) This beast is a kinda old. You've got most likely got bad
connections, maybe starter relay, and possibly cables.
Connection points corrode over time, especially if the beast
has lived in humid climates. Consider undoing, cleaning,
and reattaching ALL connection points.
3) You're absolutely on the right path looking for drops,
and obviously you see there's a horrible problem on both
high and 'ground' sides...
Hope that helps, and let us know what you find!
Best Regards, Dave
Old July 14th 20, 05:11 AM posted to rec.aviation.soaring
2G
The inrush current demand of a starter can be as much as 150 amp. Obviously, any resistance in the circuit (and I do mean any) will result in a substantial voltage drop, but not 3 - 3.5 V. You have a corroded connection somewhere. Replacing the cables WILL NOT solve the problem (unless they are damaged). You must find the bad connection(s). Taking everything apart and polishing them down to bright metal is the solution.
Your battery is bad and needs to be replaced (no surprise there). Typically they have 10 milliohms of internal resistance which means a 1 V drop at 100 amp. Any more means the internal resistance has gone up to the "toss it" level.
Tom
Old July 14th 20, 06:08 AM posted to rec.aviation.soaring
Tango Whisky
The Ventus cm starter pulls 50 amps max. If the starter relay is bad (not the connections), the starter will spin without engaging into the starter wheel.
Old July 14th 20, 12:45 PM posted to rec.aviation.soaring
True, but the relay might have two functions. One described is about physically moving the gear to engage the flywheel. The other function is to connect the starter to the battery. It could be wimpy at the second but still ok at the first.
Divide and conquer is a great plan for finding this. You already started measuring the + and - paths separately. Maybe look in more detail. Can you measure to the wire in the middle to figure if a particular connection or the relay is most of the drop. Assuming the bolted connections are clean and tight, that leaves the crimps where the wire ends are connected to the lugs, the starter relay internals, and the wire itself where it flexes going up and down. Maybe the voltmeter can isolate further.
Good luck.
Old July 14th 20, 02:04 PM posted to rec.aviation.soaring
AS
Tom
You can get a relatively inexpensive IR camera for your smart phone and take a look at the whole system while starting. Bad connections will show up quickly as hot-spots. Great trouble shooting tool.
Uli
'AS'
Old July 14th 20, 09:41 PM posted to rec.aviation.soaring
Tom
Uli
'AS'
Thank you all for all the answers and advises.
I´ll try to reasume all the thing I´ve done on my glider.
This glider belonged originally to David Noyes (NL) in USA.
I bought it in 2017 to its 3rd owner C. Collman and imported to Argentina.
Since then, it started regularly but always with very few power, giving me doubts if i had to restart while flying to fly back home. Fortunately, it started all the times I really needed. (no more than 6)
I made a service to the original electric starter and it improved a little.
After one and a half year, dec 2018, first thing I replaced was Battery. I bought an Odyssey PC680, 12V 16Amp... but the problem was not yet solved.
Last year I decided to bought a new starter (the same as original), new relay (the same as original) and new coils and of course new spark plugs, and sparkplugs cables, etc etc.
I changed everything while applying an AD (propeller bearing replace) last year, and during last summer it seemed to be doing well.(we also found other problems that were repaired)
Now, after quarantine, I noticed the starter was running slow again and I began to inspect the electric installation.
This glider`s electric system is very simple: The positive wire goes from the battery directly to a 50Amp masterswitch/fuse. Then goes directly to the relay and then to the starter. The negative wire goes directly from battery to the engine pylon where starter is screwed.
The drops of voltage are (divided by section):
0-On battery: 3V. !! (measuring battery poles) (no voltage drops on connector)
1-from battery to fuse: 0.3V.
2-on the fuse: 0.22V.
3-from fuse to relay: 0.85V
4-on the relay: 0.2V
5-from relay to starter: 0.55V
Total drop on positive wi 2.12V (the drops on the wire are proportional to the lenght of each section of wire) (total lenght of wires is more than 5 meters)
Total drop on negative wi 1.4V
Total drop of voltage: 3.5V + 3V (battery) = 6.5V. Voltage on starter is 6.2 when battery is 12.7 !!
Tests done duplicating wires improves 1.4 volt on the starter. All the contacts are in good condition and clean.
So, the battery is a very good one (at least that is what the seller told me and what i could investigate myself) and is 1.5 years old, used for no more than 100/120 starts (including all the test I did).
The relay is new. The starter is new….( Less use than the battery)
I can't find a certain place where there are point voltage drops. I'm totally lost. I don´t want to buy a new battery and find that wasn´t the problem.
Next to do, I will measure the current with a DC Amperimeter in order to check if starter is consuming more tan normal.. It is labeled 400W, so it should consume no more than 35 Amp. And I will try to get borrowed another battery to compare.
One thing to make clear: once the engine starts it runs perfectly with any problem. Never stopped itself. No carburation problems.
But i am thinking now:… Could the engine be hard? Heavy? Even if i decompress it to start spinning
Regards,
Lucas
Ventus 2 ASI problems? John McLaughlin Soaring 4 February 15th 20 02:09 AM
Starting out the top [email protected] Soaring 4 November 9th 13 04:04 PM
Starting a 135 op? Dan[_1_] Piloting 32 February 22nd 08 02:13 PM
Just starting out... Jase Vanover Piloting 20 April 24th 05 08:23 PM
Starting FS9 Hector Relva Simulators 1 September 22nd 03 02:21 PM
