Swivel On Winch Cable
Old April 20th 05, 07:43 AM
John Sp
Default Swivel On Winch Cable
Tost's cable handling notes prohibet the use of a swivel between the cable
and winch parachute They say it destroys the multistrand cable.- Swivel is
only to be used for towing out.
THis is counter intuitive - can anyone offer an explanation why this is so?
Thanks
John Spargo
Old April 20th 05, 09:32 AM
Stephen
"John Sp" wrote in message
so?
Thanks
John Spargo
If you use a swivel the cable will untwist when under tension and then turn
itself into a rats nest when the tension is removed. My club uses a swivel
that doesn't work when under tension. I'm not sure it would twist during
towing out either. As far as I can see the only purpose of the swivel is to
prevent the cable twisting as the parachute spins on the way down after a
launch.
Stephen
Old April 20th 05, 12:11 PM
Phil Jeffery
so?
Thanks
John Spargo
It is normal to use a swivel that locks when launching to prevent the cable
un-twisting whilst under load which would destroy its structure. However,
it is desirable to then permit swivelling whilst the cable is retrieved
after glider release to prevent the parachute from winding-up the cable.
This is normally achieved by having the two sections of the swivel joined by
a plain bolt without any form of bearing incorporated.
The only use for a freely operating swivel is when retrieving the cable once
or twice under a fairly light load when it has been newly fitted and prior
to launching any gliders. It is considered by some that this helps to bed
the strands in and reduce the springiness in a new cable making it less
prone to cause loops at the winch in the event of a glider release under
tension.
Phil Jeffery
Stuck cowl flap cable Jim Burns Owning 7 March 24th 05 02:07 PM
Winch Cable Splicing (w/o ferrules) Gary Emerson Soaring 11 April 5th 04 06:51 AM
best Winch cable? yo Soaring 2 April 2nd 04 03:47 PM
Winching - Cable danger. W.J. \(Bill\) Dean \(U.K.\). Soaring 9 March 27th 04 11:51 PM
Winch cable Bill Daniels Soaring 5 August 24th 03 11:13 PM
