Starting SeeYou
Old July 16th 20, 08:41 PM posted to rec.aviation.soaring
Tony[_5_]
Default Starting SeeYou
I have been having a lot of trouble lately getting SeeYou to boot up on my computer. Naviter suggested I disable antivirus and try using SeeYou Cloud. They like to suggest the cloud. I prefer that the actual software just work, but I feel I am getting old fashioned.
Has anyone else had trouble getting SeeYou to boot lately?
Old July 16th 20, 09:53 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
a couple versions ago, I was advised to disable IBM Security Rapport. Solved the problem at the time.
Old July 16th 20, 11:25 PM posted to rec.aviation.soaring
Tony[_5_]
Yea he mentioned that. I have a Dell, no IBM ware that I know. just Windows "Security"
Old July 17th 20, 03:19 PM posted to rec.aviation.soaring
If installed, it's an extension to your web browser, and is used by finanical institutions to augment online banking security. Not related to hardware manufacturer.
Old July 24th 20, 04:02 AM posted to rec.aviation.soaring
Tony[_5_]
Nothing IBM in the Extensions on Chrome. SeeYou Logs sent to Naviter. I can't be the only one in the world who is having this issue??
Old July 24th 20, 02:43 PM posted to rec.aviation.soaring
George Underhill
I've found SeeYou to be extremely slow to load. Not sure exactly when the problem started, but I believe it was after I extended my subscription after it lapsed for quite a while (years?). Perhaps an upgrade is to blame? I have an SSD and I don't believe it's a security issue. I'm also using the included security on Windows 10 and nothing else.
Old July 24th 20, 10:00 PM posted to rec.aviation.soaring
2KA
When you say "a lot of trouble", can you be more explicit about what happens? Does it eventually start if you wait a long time? Or does it give some kind of error message? If the latter, what is the message? Does it sometimes start and sometimes not?
Are you running the current version?
SeeYou is working just fine for me, and starts normally -- which is a bit slow. It usually takes something like 20-30 seconds.
Lynn Alley
"2KA"
Old July 25th 20, 02:27 AM posted to rec.aviation.soaring
Tony[_5_]
15ish minutes to finally start yesterday. No error messages. Latest version.
Old July 25th 20, 02:33 AM posted to rec.aviation.soaring
Ron Gleason
Version 10.33 of SeeYou, 12 seconds to launch. Tony, like your glider you need to upgrade your PC equipment 8-)
Old July 25th 20, 02:36 AM posted to rec.aviation.soaring
Tony[_5_]
Don't even get.me started Ron. The only reason I was.forced.to update to a new laptop was because SeeYou quit supporting Windows 8 or whatever I had.on my old laptop. They did so with no notification and still listing Windows 8 as a support OS on the website! So like a fool I did the update and all the sudden the program wouldn't work. That years subscription was.exoensive since I had to buy a new computer!!
No other program on my laptop seems to be having issues...
Starting a 135 op? Dan[_1_] Piloting 32 February 22nd 08 02:13 PM
An-2 starting Jaroslaw Manek Aviation Photos 0 May 27th 07 08:30 PM
Seeyou NMEA to Winpilot/Seeyou Jean Soaring 4 June 3rd 06 11:38 AM
Just starting out... Jase Vanover Piloting 20 April 24th 05 08:23 PM
Starting FS9 Hector Relva Simulators 1 September 22nd 03 02:21 PM
