question about 303 Mosquito canopy operation
Old July 25th 20, 05:35 PM posted to rec.aviation.soaring
Default question about 303 Mosquito canopy operation
I’m building a 1-pc canopy for my HP-16 and I like the 303 Mosquito hinge method of unequal length arms. I’ve seen photos of the canopy but don’t understand what prevents the fwd hinge links from sliding fwd in the slot prematurely and striking the fuselage. Do the springs that assist in opening the canopy also pull aft and keep the fwd links at the aft end of the slot? Or, do the canopy stops that limit fwd travel wedge against something like a cam and push the links aft in the slot while the canopy is in motion?
Thanks, Brian
Old July 25th 20, 09:14 PM posted to rec.aviation.soaring
Dan Marotta
I owned a Mosquito back in the late 80s and I don't remember any springs
associated with the canopy.Â* As I recall, you simply lift the canopy up
and rotate it forward and it slides on tracks with mushroom shaped
buttons running inside the tracks.
Sorry I can't be more descriptive...
Thanks, Brian
Dan, 5J
Old July 26th 20, 03:53 AM posted to rec.aviation.soaring
Brian[_1_]
I looked into it for my HP16. As I recall the front arms is shorter and rotate almost 180 degrees (maybe 160, would require some modeling to determine the geometry). The back arms longer (maybe twice as long as the front arms) so that it goes just about vertical (rotates 90 degrees).
Hope that helps, never got around to doing it with my HP16.
Brian
Old July 26th 20, 04:13 PM posted to rec.aviation.soaring
Scott Williams[_2_]
Thanks, Brian
Hey Brian,
This last year I bought a 303 mosquito.
The canopy mechanism is 'clunky' but works well and would be vastly easier to fabricate vs a more common front hinged canopy (read asw, etc)
FWIW,
Scott, N99300
Old July 26th 20, 04:26 PM posted to rec.aviation.soaring
I lightened this image and it shows more detail of the right, front canopy link and the spring-loaded arms I referenced in my first post. I suspect those two coil springs assist in raising the canopy and spring tension may be the only force holding the canopy linkage at the aft end of the slot.
Brian T
https://photos.app.goo.gl/NksLdmdciW9xMS6aA
Old July 26th 20, 11:35 PM posted to rec.aviation.soaring
Brian[_1_]
The slot is probably what I missed when I was modeling it. The local 303 had been gone for a number of years before thought about putting this system on the HP. So I could only do it from memory.
Mosquito question [email protected] Soaring 4 July 26th 16 01:45 AM
Tinted Canopy question Soartech Soaring 1 August 7th 13 01:36 PM
Canopy question [email protected] Aviation Photos 5 January 27th 13 07:54 PM
REQ: Mosquito FB Mk VI Canopy Pictures Ed Kettler Aviation Photos 4 December 28th 07 02:52 AM
Canopy question Neal Fulco Home Built 2 October 14th 03 07:13 PM
