https://en.wikipedia.org/wiki/Halberstadt_D.II
The Halberstadt D.II was a biplane fighter aircraft developed and manufactured by German aircraft company Halberstädter Flugzeugwerke. It was adopted by the Luftstreitkräfte (Imperial German Army Air Service) and served through the period of Allied air superiority in early 1916. As the first biplane configuration fighter aircraft to serve in combat for the German Empire, it had begun to be superseded in the Jagdstaffeln and other early German fighter units by the superior Albatros fighters in the second half of the year, although small numbers of Halberstadts continued in use well into 1917. The D.II was the production version of the experimental D.I. Key differences between the D.I and D.II included a substantial effort to lighten the aircraft in order to improve its performance; the latter also featured staggered wings and the adoption of a more powerful 120 hp Mercedes D.II engine. The side and frontal radiators that had been tried in the D.I were replaced by a wing mounted radiator, similar to the arrangement that was later used by the Albatros D.III and D.V. In comparison with the D.I, the pilot sat higher in his cockpit, to improve his view over the top wing. This required a dorsal turtleback fairing over the rear fuselage, to improve its lines. The two bay wings were very strongly braced, but the trailing edge was composed of a wooden member, as opposed to the wire or cable common on many of the First World War-era German single-engined aircraft. Photographic evidence indicates that many examples were rigged with washout on the lower wings – giving the impression of a curved or twisted lower wing trailing edge. In some photos even the upper wings have a similar sort of "trailing edge droop" on the fixed section inboard of the ailerons. Lateral control was by ailerons, but the Morane-style empennage (common not only to Moranes, but also to the Fokker and Pfalz types of the period) was retained. The inevitable result was extreme fore-and-aft sensitivity and poor control harmonization. The D.II was nonetheless considered to be very manoeuvrable in skilled hands: in particular it could reputedly be dived safely at high speed. A single synchronised lMG 08 "Spandau" machine gun fired through the propeller arc. If the only performance figures available for the type are accurate, the Halberstadt fighter's speed and climb were little better than the Eindecker's, but it earned the respect of Allied fighter pilots and was a preferred mount of the pilots of the early Jagdstaffeln, until the Albatros D.I became available. Halberstadts were actually retained, or even returned to service by some pilots during the early weeks of 1917, at a time when the structural difficulties with the Albatros D.III first surfaced. Role Fighter Manufacturer Halberstädter Flugzeugwerke also under license to Aviatik Hannoversche Waggonfabrik Designer Karl Theis First flight Late 1915 Introduction Early 1916 Retired 1917 Primary user Luftstreitkräfte Produced 1916 Number built 65 Like other early German fighter types, the D.II was at first supplied in ones and twos to the ordinary six-aircraft reconnaissance units or Feldflieger Abteilungen of the German Air Service: then from February 1916 onward through the summer of that year gathered into small specialised fighter units – the Kampfeinsitzer-Kommandos or "KEK" units. When the first true fighter Jagdstaffeln were formed in mid-1916, the Halberstadt was the best fighter available and was used by Oswald Boelcke to demonstrate his famous pioneering air fighting tactics (the Dicta Boelcke) to the new units (although he is also recorded as flying a Fokker D.III at this period). His Halberstadt was painted bright blue – one of the first documented instances of the gaudy personal finishes applied by German fighter pilots to their mounts for the remainder of the war. For some reason, the Halberstadt-built D-series fighters bore no marked IdFlieg-issued military serial numbers anywhere on their exteriors. The licence-built Aviatik and Hannover-constructed examples of the Halberstadt D-series fighters usually had IdFlieg-issued serial numbers on their rear fuselage sides. As the new Albatros fighters came into service the Halberstadts were quickly replaced, although a few survived into early 1917. Manfred von Richthofen flew a red Halberstadt D.II for a few weeks in February and March 1917, after the spar of the lower wing of his Albatros D.III cracked in combat. Variants Aviatik of Germany built the D.II under licence. It was originally known as the Aviatik D.I (not to be confused with their Austrian subsidiary's independently-designed Aviatik (Berg) D.I) but was later called the Halberstadt D.II(Av). The Halberstadt D.III primarily differed from the D.II version in its substitution of the Argus As.II 90 kW (120 hp) straight-six engine, which differed from the usual Mercedes D.II powerplant in having its camshaft in the engine block and using pushrods to operate the overhead valves, rather than having a camshaft running atop all of the cylinders as in a single overhead cam engine. A total of 50 D.III examples were built by Halberstadt, with the first 30 ordered in July 1916 and the last 20 ordered in August 1916. The D.IV version, of which only three were built to an order placed in early March 1916, changed the wing bracing layout to a single bay, dispensed with the twin bracing struts for the "all moving" vertical tail rudder surface, and used a Benz Bz.III 110 kW (150 hp) straight-six engine for power, with a small conical spinner for better streamlining. Tested by IdFlieg in October 1916, this type was rejected for further evaluation due to a poor forward field of view for the pilot. The D.V version was a less radical departure from the earlier D.II version and mostly differed from the D.II, in having its four-member cabane strut structure supporting a central panel for the upper wing, rather than both upper wing panel's wing roots meeting along the centreline of the aircraft, for better forward pilot vision. It also used the D.III version's Argus As.II engine and changed the mounting position of the aircraft's 7.92 mm (.312 in) lMG 08 machine gun from the right to the left side of the nose. A total of 57 D.V aircraft were built, from orders placed in October 1916 and January–June 1917, with 31 of these being sent to Germany's ally in the Central Powers, the Ottoman Empire. Specifications (D.II) General characteristics Crew: 1 Length: 7.3 m (23 ft 11 in) Wingspan: 8.8 m (28 ft 10 in) Height: 2.66 m (8 ft 9 in) Wing area: 23.6 m2 (254 sq ft) Empty weight: 519 kg (1,144 lb) Gross weight: 728.5 kg (1,606 lb) Powerplant: 1 × Mercedes D.II 6-cylinder water-cooled in-line piston engine, 90 kW (120 hp) Propellers: 2-bladed fixed-pitch propeller Performance Maximum speed: 150 km/h (93 mph, 81 kn) Range: 250 km (160 mi, 130 nmi) Service ceiling: 4,000 m (13,000 ft) Time to altitude: 1,000 m (3,281 ft) in 3 minutes 30 seconds 2,000 m (6,562 ft) in 8 minutes 30 seconds 3,000 m (9,843 ft) in 14 minutes 30 seconds 4,000 m (13,123 ft) in 22 minutes 30 seconds 5,000 m (16,404 ft) in 38 minutes 30 seconds Armament Guns: 1 × forward-firing 7.92 mm (.312 in) lMG 08 "Spandau" machine gun * |
| Thread Tools | |
| Display Modes | |
| Dogs Of War, pt 2 - Halberstadt D-III of Jasta 4.jpg (1/1) | Mitchell Holman[_9_] | Aviation Photos | 0 | May 28th 19 02:53 PM |
| Dogs Of War, pt 2 - Halberstadt CL-IV of Flieger Abt III.jpg (1/1) | Mitchell Holman[_9_] | Aviation Photos | 0 | May 28th 19 02:53 PM |
| Dogs Of War, pt 2 - Halberstadt CL-IV 9455-18.jpg (1/1) | Mitchell Holman[_9_] | Aviation Photos | 0 | May 28th 19 02:53 PM |
| The Dogs Of War - Halberstadt CL-IV of Flieger Abt III.jpg (1/1) | Mitchell Holman[_7_] | Aviation Photos | 0 | January 10th 14 03:25 PM |
| The Dogs Of War - Halberstadt CL-IV 9455-18.jpg (1/1) | Mitchell Holman[_7_] | Aviation Photos | 0 | January 7th 14 03:55 PM |
