Ader Éole
Old February 1st 20, 01:46 PM posted to alt.binaries.pictures.aviation
Miloch
Default Ader Éole
https://en.wikipedia.org/wiki/Ader_%C3%89ole
The Ader Éole, also called Avion, was an early steam-powered aircraft developed
by Clément Ader in the 1890s and named after the Greco-Roman wind god Aeolus.
Unlike many early flying machines, the Éole did not attempt to fly by flapping
its wings, but relied on the lift generated by its wings in forward motion. With
wings resembling mechanical copies of bat wings, its steam engine was an
unusually light-weight design driving a propeller at the front of the aircraft,
but lacking any means for the pilot to control the direction of flight.
According to late 1907 claims made by Clément Ader, on 8 October 1890, the
machine achieved a short flight of around 50 m (164 ft) at the Chateau
d'Armainvilliers in Brie. It reached a height of around 20 cm (8 in). The poor
power-to-weight ratio of the steam engine and bad weather were felt to limit the
flying height achieved. Ader later claimed to have flown the Éole again in
September 1891, this time to a distance of 100 m (328 ft), but this claim is
less substantiated.
Some consider the Éole to have been the first true aeroplane, given that it left
the ground under its own power and carried a person through the air for a short
distance, and that the event of 8 October 1890 was the first successful flight.
However, the lack of directional control, and the fact that steam-powered
aircraft proved to be a dead end, both weigh against these claims. Ader's
proponents have claimed that the Wrights' early airplanes required a catapult to
take off; however, the Wrights did not use a catapult for their first flights in
1903, though they did for many flights in 1904 and later.
Modern attempts to recreate and evaluate the craft have met with mixed results.
A full-size replica built in 1990 at the École Centrale Paris crashed on its
first flight, injuring its pilot and leading to the termination of the
experiment. Scale models, however, have been successfully flown.
Role
Pioneer aircraft
National origin
France
Designer
Clément Ader
First flight
9 October 1890
Number built
1
Specifications (Éole)
General characteristics
Crew: 1
Length: 6.5 m (21 ft 4 in)
Wingspan: 14 m (45 ft 11 in)
Wing area: 28 m2 (300 sq ft)
Empty weight: 226 kg (498 lb)
Gross weight: 330 kg (728 lb)
Powerplant: 1 × Ader alcohol-burning steam engine, 15 kW (20 hp)
Performance
Maximum speed: 58 km/h (36 mph, 31 kn)
Wing loading: 8 kg/m2 (1.6 lb/sq ft)
Power/mass: 0.05 kW/kg (0.03 hp/lb)
First fly in 1890 by Clement ADER (France) Platon67 General Aviation 15 December 19th 03 11:38 PM
