Garmin 296
Old April 28th 05, 11:01 AM
Default Garmin 296
I've used a 295 for aviation purposes since it came out and a Street
Pilot III for auto trips.
Recently, issues developed with reestablishing the update chain for the
SP III road map software.
So, I decided to upgrade to a 296, which does "trains, planes, and
automobiles." (Actually, aviation, automotive, and marine).
What a awesome unit! So much better than the 295 and soooooo much
faster than the SP III when doing automotive routes and recalculations.
The "TAWS" mode alone is worth the price of admission. I ran the
Henderson/NASCAR King Air CFIT crash in the simulation mode. There was
plenty of warning from the 296 along that track and at their presumed
altitude. Even if their altitude changed once the TRACON lost radar,
they still would have received timely warnings. Also, with the
situational awareness affored by the map (this is true of the 295 as
well) they probably wouldn't have gone where they went.
Old April 28th 05, 04:51 PM
Robert M. Gary
I love my 296. I dumped my 295 years ago because Garmin was so far
behind the technology curve for so long. With the 296, they've caught
up. I sold my Skymap IIIc for an amount that covered much of the new
296.
The one critical problem with the 296 is the lack of airways. It was
hard to get rid of my King Skymap IIIc. Out West airways rule because
they thread us through the mountains. Having to go back to the old
VOR/DME method of flying the airways is disappointing but the 296 has
enough features that I'm otherwise happy. The terrain feature of the
296 is better than the SkyMap IIIc.
-Robert
Old April 29th 05, 01:55 AM
An airway database would sure be nice. But, at least we have a 300 leg
flight-plan capability unlike the IFR 400/500 units.
296.
-Robert
Old July 13th 05, 07:00 PM
Richard Kaplan
Why not enter a flight plan on the 296 with the waypoints which describe an
airway? That works great to backup and simplify VOR navigation.
Richard Kaplan
www.flyimc.com
Old July 17th 05, 04:29 AM
RjL
Geez - what could be simpler than tracking an airway by VOR navigation? Is
following the little magenta line really easier than "needle left, fly left"
I love GPS, but really - this is an IFR forum.
"Richard Kaplan" wrote in message
news:1121277531.0fef1f7f9e9f8c1fe30e3b62c2736376@t eranews...
an airway? That works great to backup and simplify VOR navigation.
Richard Kaplan
www.flyimc.com
Old July 17th 05, 02:58 PM
Richard Kaplan
"RjL" wrote in message
left"
Portable GPS can back up but not replace a VOR receiver on airways.
However, yes, a backup GPS can make things quite a bit easier at times.
One example is when you are close to the VOR station and the VOR needle is
highly sensitive. Another example is to help establish a crab angle when
flying an airway with a signficant crosswind aloft. Yet another example is
for situational awareness with respect to weather or alternate landing
sites. There are dozens more ways a portable GPS can be quite helpful to
an IFR pilot as a backup navigational device.
Richard Kaplan
www.flyimc.com
Old July 17th 05, 03:07 PM
john smith
Richard, I need you to explain this statement.
VOR doesn't care what heading the airplane is flying, so how does the
crab angle affect the track if you are keeping the needles centered? You
simply adjust your crab angle right or left to maintain the track, correct?
Old July 17th 05, 03:26 PM
Steven Barnes
"john smith" wrote in message
correct?
I use my Pilot III or the panel mounted VFR GPS for this purpose, also. Get
the needle centered. Get a heading that makes my track equal the VOR radial
I want. Done. Double check every x minutes as needed. Handy on approaches,
too. Don't even have to have a way-point in the box. Just look at the
current ground track.
Although, I'm starting to get spoiled. Hafta declare an emergency if my GPS
goes out....
Old July 17th 05, 03:46 PM
Richard Kaplan
VOR doesn't care what heading the airplane is flying, so how does the crab
angle affect the track if you are keeping the needles centered? You simply
Yes, that is how you do it with only a VOR receiver. It is somewhat a
matter of trial and error to determine the proper crab angle and that crab
angle will change if the winds aloft change.
However, if you have a portable GPS with a simulated HSI such as the Garmin
296, it makes the process of determining and modifying crab angles almost
automatic. The electronic HSI on a Garmin 296 knows only your track and not
your actual heading. So if you set the "heading" on the electronic HSI to
the desired course, you will actually be establishing whatever crab angle is
needed to maintain the desired course. This greatly simplifies the workload
of navigating with a crosswind.
Richard Kaplan
www.flyimc.com
Old July 17th 05, 05:58 PM
Jonathan Goodish
It may be simple, but it's not all that accurate compared with GPS,
especially if you're a ways out from the VOR.
JKG
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 02:04 AM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
