Flight Log Not Complete
Old September 5th 20, 04:05 AM posted to rec.aviation.soaring
[email protected][_2_]
Default Flight Log Not Complete
After my glider flight today I downloaded my flight log from the LX9050 to an SD card as usual. When uploading for an OLC claim I get the message "A clock jump was found in the recording. The flight was shortened from there". Only the last 7 minutes of the flight is indicated. It was a 3 hour flight and the file size is the about the same for my other flights of similar duration. I won't know if this is a one time thing or if there is a bigger problem until I fly again. Has anyone else had this happen?
Old September 5th 20, 01:37 PM posted to rec.aviation.soaring
Paul Remde
Hi Terry,
I recommend updating the firmware in the LX9050 to the latest version. I think the date jump issue was fixed a while ago.
Best Regards,
Paul Remde
__________________________________
Old September 5th 20, 03:29 PM posted to rec.aviation.soaring
Dan Marotta
Yes, and if you have another logger, use it!Â* I have had one fail and
simply downloaded the other one.Â* Does whatever vario you use with your
LX have a flight recorder?Â* OLC is not world record stuff, after all.
On 9/5/2020 6:37 AM, Paul Remde wrote:
Hi Terry,
Best Regards,
Paul Remde
Dan, 5J
Old September 5th 20, 04:12 PM posted to rec.aviation.soaring
Tango Eight
LX have a flight recorder?Â* OLC is not world record stuff, after all..
Hi Terry,
Best Regards,
Paul Remde
Dan, 5J
OLC needs to quit making up requirements that go beyond igc.
T8
Old September 7th 20, 02:41 AM posted to rec.aviation.soaring
Steve Bralla
T8
True but maybe ClearNav needs to fix their problems.
Old September 6th 20, 02:13 AM posted to rec.aviation.soaring
Terry Edmonds
On Saturday, September 5, 2020 at 7:37:47 AM UTC-5, Paul Remde wrote:
Hi Terry,
Best Regards,
Paul Remde
Paul; Today I updated the LX9050 firmware to the latest version 800. The previously installed version was 607. Do you believe the date jump fix was between those two versions? I flew a short 40 minute test flight and the log was good on it.
Terry
Old September 6th 20, 12:00 PM posted to rec.aviation.soaring
Check the logging interval. (He said the file was the correct size. The data is there.) By changing your logging interval from 1 second to 4 when you load the file onto the SD card from the 9050 the clock jump gets overlooked and you can get OLC to accept your flight. Act quickly!
Doug
W24
How to complete a 337? Michael Horowitz Home Built 12 August 24th 09 05:04 PM
Complete HP-18 Sailplane Kit Wayne Paul Home Built 0 August 17th 06 04:31 PM
Complete HP-18 Kit Wayne Paul Soaring 0 August 17th 06 04:31 PM
For Sale: L-Nav, Gps-Nav, complete [email protected] Soaring 0 November 22nd 05 12:23 PM
Complete Idiots? John Galban Piloting 1 July 1st 04 06:14 PM
