![]() https://en.wikipedia.org/wiki/Taylor...F-19_Sportsman see also https://en.wikipedia.org/wiki/Taylorcraft_F-21 The Taylorcraft Model F-19 Sportsman is a two-seat cabin monoplane designed and built by Taylorcraft Aircraft as the first new product of the reformed Taylorcraft Aviation Company. The F-19 fuselage is a fabric-covered 4130 steel tube framework; its wing was fabric-covered wood. It has conventional landing gear and a tractor configuration 100 hp (75 kW) Continental O-200 engine. C.G. Taylor and his brother formed the Taylor Brothers Aviation Corporation in 1929, which had produced several thousand light single-engines by the time it went bankrupt in 1946. It emerged in 1947 as Taylorcraft Inc. and produced light airplanes until 1958, when it ceased production. In 1968 a new company, Taylorcraft Aviation Corporation, was formed, primarily to provide support for the thousands of airplanes still in the field. However, in 1973 this company geared up to produce an updated Taylorcraft B, now named the Model F-19 Sportsman. It was similar to the Model B but incorporated more power, which resulted in better performance. Production continued until early 1980, when the company chose to switch to the higher-powered Model F-21. Role Two-seat cabin monoplane National origin United States Manufacturer Taylorcraft Aviation Corporation First flight 1973 Introduction 1973 Number built 120 Variants Taylorcraft F-21 Specifications General characteristics Crew: 1 pilot Capacity: 1 passenger Length: 22 ft 1¼ in (6.74 m) Wingspan: 36 ft 0 in (10.97 m) Height: 6 ft 6 in (1.98 m) Wing area: 183.71 ft2 (17.07 m2) Aspect ratio: 7.05 Empty weight: 900 lb (408 kg) Gross weight: 1500 lb (680 kg) Powerplant: 1 × Continental O-200, 100 hp (75 kW) Performance Maximum speed: 127 mph (204 km/h) Cruise speed: 115 mph (185 km/h) Range: 400 miles (644 km) Service ceiling: 18,000 ft (5,485 m) * |
Bush Flying, pt 5 - Glastar Sportsman 02.jpg (1/1) | Mitchell Holman[_9_] | Aviation Photos | 0 | January 25th 19 01:40 PM |
Bush Flying, pt 5 - Glastar Sportsman 01.jpg (1/1) | Mitchell Holman[_9_] | Aviation Photos | 0 | January 25th 19 01:40 PM |
Taylorcraft Auster pics 2 [7/8] - taylorcraft-auster-reconnaissance-1945-5-hms-khedive-artillery-spotting-rangoon-iwm-a28832.png (1/1) | Miloch | Aviation Photos | 1 | August 7th 17 03:08 AM |
Bush Flying, pt 4 - Glastar Sportsman.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | January 21st 09 01:01 PM |
Planes On Poles, pt 6 - Sportsman-two.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | January 23rd 07 01:55 AM |
