Felt
Old September 15th 20, 10:54 PM posted to rec.aviation.soaring
Jay Campbell
Default Felt
Many of you use, or could use, felt for lots of things in your trailers (fitments, pads), your dollies, wing stands (maybe). I know that over the years, felt has been a part of every one of my winter's project list.
I used to have an industrial supplier "down the street" and got off-cuts from him but he went of business about the time I retired. Today a found a company that answered the phone with a human being that knew what they were talking about. May I recommend that, if you need felt for one of your projects, give these folks a call. Very helpful. There may be a minimum order issue, but if you are in a club, there are probably others that could help you with that.
https://www.thefeltpeople.com/about-us/
Old September 15th 20, 11:20 PM posted to rec.aviation.soaring
AS
Default Felt
Thanks for that link, Jay! I did buy some felt from McMaster-Carr in the past. Not sure how they stack up price-wise with your guys but it is good to have a second source.
Uli
'AS'
Old September 15th 20, 11:21 PM posted to rec.aviation.soaring
AS
Default Felt
Thanks for that link, Jay! I did buy some felt from McMaster-Carr in the past. Not sure how they stack up price-wise with your guys but it is good to have a second source: https://www.mcmaster.com/standard-felt-sheets
Uli
'AS'
Old September 17th 20, 02:34 AM posted to rec.aviation.soaring
Waveguru
Default Felt
It's been a long time since I've gotten felt...
Boggs
Old September 17th 20, 03:06 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Felt
Great stuff. Go with white synthetic felt for glider dollies, fixtures, etc, choose your thickness. Get the pressure sensitive adhesive. Peel off the paper, stick it on. The adhesive really works well.
Steve Leonard
Old September 17th 20, 03:57 PM posted to rec.aviation.soaring
Default Felt
Adhesive backing sometimes will not hold if temperatures are high and the material is not under a compression load. I often had problems with sticky-back felt on some wing or tail storage brackets when I was building trailers.. The adhesive would remain stuck to the surface, but the felt would pull away. Especially inside a trailer on hot days with no wing to hold it in place.
Sometimes a relatively heavy application of 3M Super 77 spray would do the trick, but after I started producing the WingRigger line, I became a convert to Gorilla Glue. Except when I have to remove it. Then I hate the stuff. But it's a pretty good recommendation for the adhesive qualities.
Old September 18th 20, 12:15 AM posted to rec.aviation.soaring
Default Felt
Boggs
Good one ... but these guys are far too serious about their felt.
Old September 18th 20, 03:46 AM posted to rec.aviation.soaring
Default Felt
One thing I forgot to mention about using Gorilla Glue: If you are trying to bond felt to steel, aluminum or any other smooth, non-porous surface, use some 60 or 80 grit sandpaper to scuff the surface and give a physical "toothy" grip.
Alternatively, put a layer of double-sided carpet tape on the metal, with the Gorilla Glue applied over it. The felt will soak the glue into the fiber and it will then attach firmly to the taped surface.
This is the tape I prefer:
https://www.shurtape.com/products/df-642/
Fiberglass or gel-coat surfaces are porous enough that the tape is not required.
Use nitrile gloves when working with Gorilla Glue. It is hard to clean off your skin without the aforementioned 60 to 80 grit sandpaper. It takes about a week for the residue to wear off if you don't wear gloves. About the same time it takes for the sandpaper damage to heal. Your choice.
Old September 18th 20, 10:29 PM posted to rec.aviation.soaring
Waveguru
Default Felt
I was starting to wonder if my humor was too sophisticated for everyone in this group.... I'm glad some one got my joke.
Boggs
Old September 19th 20, 09:56 AM posted to rec.aviation.soaring
R. Suppards
Default Felt
in
Boggs
There is nothing like a good joke,
And that was Nothing like a Good Joke.
Black Glareshield Felt Echo Soaring 11 May 18th 14 12:18 PM
Wool Felt for trailer fixtures now on Ebay Steve Koerner Soaring 10 April 12th 12 07:58 PM
pressure-sensitive adhesive black felt bulk order? Frank[_1_] Soaring 5 July 26th 07 05:02 PM
