Cleaning old bugs
Old September 16th 20, 09:27 PM posted to rec.aviation.soaring
cuflyer
Default Cleaning old bugs
What's the best (safest) way to get year-old bugs off a gel wing?
I tried searching old posts, but I kept getting kicked out for some reason.
TIA,
Tim
Old September 16th 20, 09:40 PM posted to rec.aviation.soaring
Tim Taylor
TIA,
Tim
Soak with soap and water first. I use a sponge and wipe down the wings several time and let soak for a few minutes. Get 3m Scotch-Briteâ„¢ Dobie or equivalent. These are sponges with a nylon netting over the sponge. These will remove the bugs well. When you are done cleaning, spray the leaning edges with Meguiar's Quik Wax and wipe down with a dry cloth. This will help limit the sticking between hard waxing or other coating you use. Best to get in the habit of wiping down the leading edges after flight, I keep a bucket about a quarter full with water in my car so I can clean while de-rigging.
Old September 16th 20, 11:28 PM posted to rec.aviation.soaring
cuflyer
Thanks, Tim. I always clean my bird after flight. I just bought this one and it had one clean wing and one forgotten wing from a year ago.
Cheers,
Tim
TIA,
Tim
Old September 17th 20, 12:17 AM posted to rec.aviation.soaring
Dan Marotta
Bounce dryer sheets.Â* The bugs melt away.Â* I learned this trick from my
motorcycling.
I keep a garden sprayer filled with pure, clean water in the hangar.Â*
After a flight, I spray the leading edges and wipe with a microfiber
cloth.Â* Easy peasy!
TIA,
Tim
Dan, 5J
Old September 17th 20, 02:17 PM posted to rec.aviation.soaring
Roy B.
Bounce dryer sheets. The bugs melt away. I learned this trick from my
motorcycling.
Wet or Dry? How does that work Dan?
ROY
Old September 17th 20, 02:22 PM posted to rec.aviation.soaring
Gianni Isotope
I use an automotive spray product, Meguiar's Quick Detailer: https://www.meguiars.com/automotive/...16-16-oz-spray
Old September 17th 20, 02:23 PM posted to rec.aviation.soaring
Gianni Isotope
Sorry, just saw TT already mentioned this
Old September 18th 20, 12:15 AM posted to rec.aviation.soaring
Dan Marotta
Wet.Â* Works great!
I used them on the windshield of my Harley but I don't think I'd try
them on my canopy.Â* Leading edges, yes.
motorcycling.
ROY
Dan, 5J
Old September 18th 20, 02:22 PM posted to rec.aviation.soaring
Sci Fi
motorcycling.
What is a 'Bounce Dryer'.. ? ( I'm English.)
Old September 18th 20, 02:39 PM posted to rec.aviation.soaring
motorcycling.
A sheet you put into the dryer while washing clothes.....it's a softener and antistatic...
... if only they can keep the bugs off Eric Greenwell[_4_] Soaring 1 August 30th 13 03:12 AM
DHMO for cleaning off bugs Jon Woellhaf Owning 19 July 8th 08 07:56 PM
Bugs - self-cleaning wings? Bill Daniels Soaring 5 February 9th 06 03:59 PM
Cleaning bugs - the real secret Maule Driver Owning 11 January 18th 05 10:38 PM
What Bugs You The Most? Charles Talleyrand Owning 14 August 21st 03 05:36 AM
