Audio Panel for Handheld
Old May 2nd 05, 05:33 PM
Default Audio Panel for Handheld
I have a panel mount Microair transceiver and Xcom Intercom in my
homebuilt. I also take along a Vertex handheld transceiver when I fly.
Does anyone know of a small, (space is very limited), audio panel that
would
allow me to switch between the Microair and handheld?
Old May 2nd 05, 05:44 PM
RST Engineering
I did a three part series in Kitplanes a couple of years ago on how to
homebrew your own audio panel for situations exactly like this.
BE AWARE OF A GLITCH IN THE MICROAIR radio that requires the key line to be
within 0.5 volts of ground in the "keyed" mode. Don't go doing any diode
switching with your audio panel design or the sucker won't key correctly.
Standard aircraft specification, by the way, is 3 volts or less is keyed,
more than 3 volts is unkeyed.
would
Old May 2nd 05, 06:13 PM
Darrel Toepfer
RST Engineering wrote:
wrote...
would allow me to switch between the Microair and handheld?
http://www.rst-engr.com/kitplanes/KP0208/KP0208.htm
Old May 2nd 05, 06:25 PM
RST Engineering
Thanks, Darryl. I am up to my hiney in hippos this morning and was going to
look this series up later this afternoon and post it. Thanks for beating me
to it.
"Darrel Toepfer" wrote in message
Old May 2nd 05, 06:39 PM
Darrel Toepfer
to it.
You mentioned a 3 parter, only you would kneaux if its complete...
It gave me a chance to grab the details on the magneto buzz box...
Old May 4th 05, 10:30 AM
NewsGroups
Its easy... just link the handheld into the second comm input on the
XCOM Intercom and then use a double pole double throw toggle switch to
select which radio you want the mic to talk on. There is information on
the XCOM website or you can email them directly for info. Regards Michael
would
Old May 6th 05, 04:20 PM
Thanks Michael, I will check it out.
Wiring cell phone into audio panel Mike Rapoport Owning 1 March 31st 05 11:06 PM
RST Audio Panel Kit Assembly Tim Witt Owning 6 March 29th 04 03:06 AM
FS KMA20 TSO Audio Panel with Marker Beacon Maik Aviation Marketplace 0 March 18th 04 04:59 PM
Garmin 340 Audio Panel Split Com O. Sami Saydjari Owning 9 January 27th 04 08:55 PM
Garmin audio panel question Brinks Owning 1 September 10th 03 08:41 PM
