On board battery(ies) for powering radios/Flarm etc
Old October 13th 20, 03:10 AM posted to rec.aviation.soaring
Neal Alders
Default On board battery(ies) for powering radios/Flarm etc
Just a quick question.
Had a brainstorm the other day, might have hit my head, don't remember, who knows...
What are y'all using for on board power these days?
Last I flew, we were using 6? amp hour gel cells by Hobbico from Tower Hobbies. (The kind that powered the little Powerwheels Jeep your kid/grandkid rode in 20 years ago)
What kind of power capacity are folks using?
I was working my big a$$ Milwaukee 10" chop saw and saw how compact the 18v, 9 amp LiPo was, and how fast it charged on the included rapid charger and got to thinking 1, 2 or 3 of those on a semi-custom mount with built in voltage regulator would be right dandy in these birds, and available at the big orange box store if a replacement is needed in a hurry.
Just a thought. Please return to your regularly scheduled mayhem.
Old October 13th 20, 03:26 AM posted to rec.aviation.soaring
Michael Bamberg
Neal,
I think there are still a lot of pilot using Sealed Lead Acid (SLA) batteries in their glider. It works OK for gliders that maybe have an electronic Vario and a radio.
As you add other electric devices, especially a transponder, the capacity demands go up. You can get SLA batteries with 12-15AH capacity, but many ships are equipped with Lithium/Iron/Phosphate (LiFePo) chemistry batteries.
Most of the sailplane accessory distributors have them in stock, for example:
http://craggyaero.com/lifepo4_battery1.htm
Hope that helps,
Old October 13th 20, 01:40 PM posted to rec.aviation.soaring
Tango Eight
Most popular are lithium iron phosphate (LFP) batteries in same form factor as those old 6AH SLAs, now typically with 9 - 10 AH capacity. Decent quality examples last for years and years with little change in capacity... and your radio still transmits
from the wave at -20C at 10% state of charge (however, do not recharge until battery warms up).
Modern (Chinese) SLAs are of poor quality, not nearly as good as what we had (at higher cost) from Western manufacturers in 1990s.
(btw, try the search function, works great, will return hours of reading on this very topic)
T8
Old October 13th 20, 02:35 PM posted to rec.aviation.soaring
Yes, I also looked longingly at the tool batteries as well. A 3d printer could make a holder/connector and there are plenty of demo boards around for switching powersupplies to make 12V.
But I decided to go with three K2's. So far I've never used the third K2.
They were already tested and in the physical and electrical form the glider expects.
LiFePo seemed more forgiving than LiIon.
I'd rather not divert the hobby from flying to building battery systems.
It seemed a thing that would be fun and easy to get close, but tricky to get right.
If the K2's didn't work so well, it might be a different story.
Old October 13th 20, 03:21 PM posted to rec.aviation.soaring
But I decided to go with three K2's. So far I've never used the third K2..
And tricky to keep a home-made kludge safe. Other types of lithium batteries are prone to spontaneous combustion. You don't want a fire in flight! A ready-made LFP battery, with a built-in circuit protecting it from over-current etc, in a proper case that fits in your glider, can now be bought for around $40 - hardly more expensive than an old-tech SLA. It's a no-brainer.
Old October 13th 20, 03:44 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
On Monday, October 12, 2020 at 7:26:11 PM UTC-7, Michael Bamberg wrote:
Neal,
Hope that helps,
Test Graph is include with every LIFEPO4 Battery sold by Craggy Aero.
Richard
www.craggyaero.com
Old October 13th 20, 04:53 PM posted to rec.aviation.soaring
jfitch
Also keep in mind that AFAIK power tool batteries (certainly the Milwaukee) have no intelligence - all the BMS functions are built into the charger and tools. So you have a volatile, uncontrolled LiPo sitting behind your head.. You can get the same AH in a well constructed, controlled LiFePo4 for the same or less money.
I'd rather not divert the hobby from flying to building battery systems..
And tricky to keep a home-made kludge safe. Other types of lithium batteries are prone to spontaneous combustion. You don't want a fire in flight! A ready-made LFP battery, with a built-in circuit protecting it from over-current etc, in a proper case that fits in your glider, can now be bought for around $40 - hardly more expensive than an old-tech SLA. It's a no-brainer..
Old October 13th 20, 06:17 PM posted to rec.aviation.soaring
George Haeh
CTEK makes a dedicated LiFePO4 charger. Not cheap, but I get some six hours running radio, PowerFLARM, vario, Oudie and transponder on a K2.
Old October 13th 20, 06:50 PM posted to rec.aviation.soaring
Neal Alders
My current gen 18v Milwaukee batteries all have on board intelligence and can signal when an issue occurs through flashing lights etc. They are highly protected against fire, shorts etc. The smaller 12v versions do not that I am aware of. The newer M28 batteries, 28 volts with capacities exceeding 40amp hours are coming around the corner. They will be integrated into generators, compressors etc. Exciting new battery tech out there.
This older platform on google groups is not very search friendly, and I was unable to locate much of anything, so I tossed the question out there.
Old October 13th 20, 06:52 PM posted to rec.aviation.soaring
Papa3[_2_]
FSC
Like others I'm using two LiFePo4 batteries (10ah K2s). I've measured my current draw (Clearnav, Clearnav vario, Trig T21, Dittel FSG 2T) and it averages 1.26A in flight on a fresh charge. Other than a 1000K flight that lasted 9 hours, I've never had to switch batteries. After 3 years, the currently older K2 still measures about 9.2ah of capacity at full charge.
P3
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
Power FLARM battery temperature Andy[_1_] Soaring 8 March 26th 13 12:32 AM
Battery Packs for Icom hand-held radios GM Soaring 1 January 19th 12 10:51 PM
Powering Mio In The Cockpit Dan Marotta Soaring 14 November 3rd 11 02:24 PM
Powering JSF: One Engine Is Enough. Mike[_7_] Naval Aviation 42 February 14th 08 09:53 PM
