AN Fittings
Old May 6th 05, 01:20 AM
Bruce A. Frank
Default AN Fittings
I have a print that, as best I can read it, calls for a fitting # AN
867-6. Is that a standard 3/8 tapered (NPT) thread fitting for welding
on fuel tanks? Can anyone point me to a chart that has pictures of the
AN fittings and possibly a translation to equiv. pipe or tube
specifications?
Bruce A. Frank
Aircraft Projects
Fuel Tank Fabrication
For Homebuilt Aircraft, Antique Fuel Tank Repair
TIG, MIG & Oxy/Acet Welding & Brazing
Old May 6th 05, 02:58 AM
Jerry Springer
specifications?
Bruce A. Frank
Aircraft Projects
Here is a web sight that has fittings and descriptions. It looks like
on about page 6 is where the AN 867- fittings are. But it looks like
3/8 is a -3. they don't list a -6.
http://www.bonacoinc.com/anstart.htm
Jerry
Old May 6th 05, 04:02 AM
Ed Sullivan
On Thu, 05 May 2005 23:20:18 GMT, "Bruce A. Frank"
specifications?
Page 158 of the current Aircraft Spruce catalog.
Old May 6th 05, 04:38 AM
ORVAL FAIRBAIRN
specifications?
There are a couple of "Standard Aircraft Handbooks" out the
1. I got one at the Airport Shoppe,at Reid-Hillview Airport.
2. Aircraft Spruce has one for $23.95, P/N 13-11400, on P. 619 of their
current catalog.
The AN 867-6D is a weldable flange fitting w/female NPT thread.
Remove _'s from email address to talk to me.
Old May 6th 05, 05:11 PM
Stealth Pilot
specifications?
just to put the correct answer here in the replies.
an867-6 is a 3/4inch female pipe thread in a weldable fitting which is
2 1/4 inches diameter by 13/16th of an inch high.
aircraft spruce has them
Stealth Pilot
Proper Torque for Fuel Fittings Steve Waltner Home Built 10 February 20th 05 01:46 AM
Fuel pump fittings Evan Carew Home Built 15 October 3rd 04 04:13 AM
37 degree fitting Ernest Christley Home Built 8 June 17th 04 04:29 AM
Need advice on Aeroquip fittings Corky Scott Home Built 2 December 12th 03 01:46 AM
Cobra trailer fittings for different glider makes & models John W Soaring 4 September 24th 03 04:21 PM
