when to run up and check the prop
Old May 6th 05, 07:47 PM
Friendly Skies
Default when to run up and check the prop
I fly some high performance, complex singles like Saratogas, Lances, C182RG,
C206, and the like. Typical flying days have multiple hops while seeing
customers. On one hand I know pilots who say that you should do a full run
up and prop check before every take off, because the checklist says to. On
the other hand, I know pilots, mostly owners of similar aircraft, who only
do a full runup and prop check on the first flight of the day. Their
rationale is that doing it four or five times a day is unnecessarily hard on
the engine and when its been flown in the last few hours there's no need to
cycle the prop more. They argue if there's a new problem during the day
like a mag, its easy to detect upon first throttle up as you take off. You
would hear and feel the engine roughness and see its not developing full
power.
Are there any good arguments out there based in science and fact and not old
wives tales to support only doing a run up and prop check on the first
flight of the day ? I'm talking about a situation where you're flying
multiple flights a day and the engine never completely cools off.
Old May 6th 05, 07:56 PM
Bob Chilcoat
I'd only run up and check the prop when the engine's not running. You can
get hurt otherwise :-)
Bob (Chief Pilot, White Knuckle Airways)
Old May 6th 05, 08:08 PM
A.Coleman
old
flight of the day ?
How about lowering the risk of an engine failure in the air by inducing any
impending failures while on the ground?
Old May 6th 05, 08:10 PM
houstondan
You can
sissy
dan
Old May 6th 05, 08:29 PM
John Galban
Friendly Skies wrote:
snip
Their
hard on
need to
I don't see why a runup or a short prop cycle should be unnecessarily
hard on the engine. If they're stopping that many times a day, they'll
get the procedure down to a few seconds.
In the backcountry, where there is often no place to runup without
sucking rocks into the prop, we often do the mag check early in the
takeoff roll. It's an extra step during a critical phase, but I
always feel more comfortable rolling towards the trees and rocks at the
end of the runway when I know all of the plugs are firing on time.
Old May 6th 05, 09:11 PM
Charles O'Rourke
You can
For some corny reason, this made me burst out laughing at work. How
embarassing.
Charles.
-N8385U
Old May 7th 05, 12:37 AM
Peter Duniho
"Friendly Skies" wrote in message
[...] Their
on
to
They may say that as many times as they wish. Without proof, it's an empty
statement.
You
power.
That argument holds as much validity for the first flight of the day as for
the Nth. Why bother doing a runup at all then?
Pete
Old May 7th 05, 02:14 AM
Mike Rapoport
C182RG,
run
On
on
to
You
power.
old
Why do they suspect that the engine/prop is more likely to fail overnight?
Why not check it on the last flight of the day? Frankly, its a stupid idea.
If they think that its too hard on their engine then they need a tougher
engine (On the Helio the mag and prop checks are done at about 15" of MP,
(not much stress)).Similiarly, if they can detect a failed mag on the
takeoff roll then why check it at all while stationary?
There are good reasons to omit a prop of mag check, gravel or ice come to
mind. The reasons are obvious.
There is also a lot of safety to be gained by doing tasks the same way in
the same order every time.
MU-2
Old May 7th 05, 02:39 AM
Tony
Ok, brother flyers, cards on the table here. I always do a run-up
before taking the active (my Mooney only sees pavement, so gravel
damage isn't a serious consideration) as do I think most of you. I'm a
M20J jock. I have, in some 3000 hours, returned to base after taxing
out only about 4 times. Once, in a normally inducted Mooney Ranger the
carb heat wire broke during that test (quite a surprise when you pull
out a foot of wire!), a couple of time because a radio wasn't working,
once because a bank of spark plugs weren't firing. Never had to come
back because the prop didn't cycle correctly.
I am NOT saying don't cycle the prop! I am wondering what failure modes
you guys have experienced during run up.
I've had in flight mag bank failures, vacuum pump failures, alternator,
radio, and common sense failures too. All but the last lead to a
landing at the nearest suitable airport (ever notice how often a
failure is in solid IFR?). The common sense failure modes did not
result in landing at the nearest airport or turning around, but they
should have.
OK, I've shown you mine. Let's see yours.
Old May 7th 05, 03:11 AM
George Patterson
Booooooo!!!!!
George Patterson
There's plenty of room for all of God's creatures. Right next to the
mashed potatoes.
Changes in Instrument Proficiency Check Requirements Richard Kaplan Instrument Flight Rules 71 June 10th 04 09:02 PM
Pitch and Diameter of 3 blade prop for IO-360 200HP Bart D. Hull Home Built 1 December 12th 03 12:42 AM
Use of hand-held GPS on FAA check ride Barry Rotorcraft 1 August 30th 03 02:24 AM
Use of hand-held GPS on FAA check ride Barry Piloting 3 August 9th 03 11:14 PM
Use of hand-held GPS on FAA check ride Barry Instrument Flight Rules 1 August 9th 03 10:25 PM
