Electric motor assisted super- or turbocharger?
Old May 8th 05, 06:13 PM
Max Kallio
Default Electric motor assisted super- or turbocharger?
2-stroke diesels need compressed air for starting the engine, so the
turbo (exhaust driven centrifugal supercharger) is out of a guestion
and it produces very little boost at low rpm anyhow.
How about supplementing a centrifugal turbocharger with a high speed
electric motor to create boost needed for starting and to enhance
boost at low rpm?
This would pretty much eliminate the turbo lag and actually help suck
the exhaust out of the cylinder at low rpm.
When the rpm rises, the electric motor could disengage or perhaps even
work as an auxilary generator.
Also, if the turbo has some problems, the electric motor could be used
at full power to help the turbo to spin and create boost at least for
the time it takes to land safely. Of course, the engine should be
able to have enough power to stay airborne at least at low altitudes
(if the load is not exeeded) even when the turbo fails completely.
Links...
www.turbodyne.com
Question about adding a second electric AI M Owning 10 January 4th 05 08:29 PM
Desktop Wallpaper - "F/A-18F Super Hornet Sunset". T. & D. Gregor, Sr. Naval Aviation 0 December 1st 04 02:08 PM
Cherokee Electric Pitch Trim Jonathan Goodish Owning 4 November 18th 04 03:43 AM
Piper Arrow electric fuel-pump MC General Aviation 7 June 3rd 04 03:50 AM
Gyros - Electric vs Vacuum? Bill Denton Piloting 1 April 18th 04 06:56 AM
