Does Av-Blend work?
Old May 10th 05, 03:14 AM
tony roberts
Default Does Av-Blend work?
Hi Peter
The aircraft that I purchased had a long history of sticking valves.
When I bought it I started adding Avblend and haven't had any problem.
I also lean aggressively on the ground and monitor engine in flight on
an EI monitor. So maybe any of those things could be responsible for my
good luck with valves - but I'm going to continue using Avblend
Tony
C-GICE
Peter wrote:
Has anyone any experience of AVblend aviation lubricant?
http://www.avblend.com/
It seems to have been around some time, and is FAA approved. The
brochure says that this oil kept a Lycoming in sound condition for
nearly 8000 hours. That's three engine lifetimes!
I remember reading years ago that this stuff AVBlend was a special oil
that "does what it says on the tin"
Peter.
Return address is invalid to help stop junk mail.
E-mail replies to but remove the X and the Y.
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old May 10th 05, 02:48 PM
Dylan Smith
It cured our stuck valve problem in the Cessna 140 I used to have (C-85
engine) so we kept using it.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
Old May 11th 05, 02:10 PM
Juan Jimenez
TBO Advisor strongly recommends the use of AvBlend on all aircraft piston
engines...
Juan
Old May 11th 05, 04:26 PM
jls
"Juan Jimenez" wrote in message
engines...
Juan
Ah, yes, well. Let them furnish their affidavies and sworn witnesses.
Their claims sound as believable as those about STP, teflon-impregnated oil,
Rube Goldberg carburetor gadgets that give 100 mpg, and the guy who got
10,000 hours on his O-320 using MMO in the gas and oil.
If the damned exorbitantly-priced stuff is so great the oil companies can
reverse-engineer it and stick it in the oil. Maybe that's what Shell did
with Aeroshell+.
Old May 12th 05, 12:23 AM
Dave Stadt
engines...
Juan
Why do they recommend it?
Old May 12th 05, 06:38 PM
Gord Beaman
Peter wrote:
Tony
Do you operate lean of peak, out of interest?
I've got an EDM700 and I certainly do, including leaning on the
ground. The engine is an IO-540-C4.
Peter
I flew the Argus equipped with Wright turbo compound engines and
we operated them leaned to 10% drop from 'best power' (peak) for
years and years. That was the recommended procedure from the
manufacturer.
-Gord.
Keep in mind that I'm an expert with
questions, so if you have any, fire
away.
Be aware however, that answers
quite often give me trouble.
Old May 13th 05, 02:38 AM
tony roberts
Hi Peter
No - I learned about it over in the Cessna Owners Group but most of the
advice there was that it is best done on fuel injected engines as the
carburettor does not distribute the fuel evenly enough.
Mine is an 0300-D 6 cyl carburated.
Walter Atkinson of Advanced Pilot Seminars is over in that group and is
very knowledgeable about lean of peak operations.
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Hey! What fun!! Let's let them kill ourselves!!! [email protected] Naval Aviation 2 December 17th 04 09:45 PM
Best Home Base Work Reynard Simulators 0 November 9th 04 04:39 PM
Best Home Base Work Reynard Instrument Flight Rules 0 November 9th 04 04:37 PM
