out-gassing of garment soils in deep space?
Old May 9th 05, 06:01 AM
Default out-gassing of garment soils in deep space?
Meanwhile, over in a Mars discussion board, the question has been
raised about whether one can clean garments during an inter-panetary
mission, just by exposing them to the vacuum of deep space.
Let us presume that the major soils are body oils of the groin and
axillary areas.
Old May 10th 05, 12:43 PM
Denny
Volatiles will out gas off the fabric... Solids will remain behind...
Many viruses will survive... Bacteria may or may not survive, depending
upon multiple factors... Those buried deep within the feces/sweat
smears will have a partial percentage of survivers... Stains will not
go away... The clothing will not look or feel fresh... You will still
need the magic of detergents and agitation followed by a clean water
rinse, before drying the clothes just like dear old mom did; by
hanging them on the clothes line in the back airlock and cycling it
open on laundry day...
The combination of a hard vacuum and exposure to direct sunlight will
be more effective... The high temperature of the sunshine (dark colors
will probably smoke a bit) and the hard UV radiation is an effective
germicide... Though, your clothing will rapidly fade and become raggedy
under intense UV and Xray bombardment from the Sun...
You can do your own vacuum test out in the garage (though radiation is
a bit harder to simulate) by putting some really nasty underwear in a
can, heating it to 250F, and pulling a hard vacuum on it for a day or
two, then remove the shorts and smear the crotch all over your
tongue... Taste anything?
cheers ... Dr. denny
Old May 19th 05, 07:00 AM
Capt.Doug
"Denny" wrote in message
It tasted like dirty underwear.
The smell however was different. It smelled like some pilots I met at a
fly-in in Indiana.
D.
Old May 13th 05, 01:41 AM
Rich S.
"pete" wrote in message
` There is a problem: it gets cold in space. :-) Will a heater
` be involved?
Make all the clothes out of teflon, then roast 'em at 300C to clean 'em.
Oops! Problem with that. The fumes will kill your parrot, then where will
you be?
Rich S.
Old May 14th 05, 03:22 AM
pete
In sci.space.tech, on Thu, 12 May 2005 17:41:52 -0700, Rich S. sez:
` "pete" wrote in message
` ` There is a problem: it gets cold in space. :-) Will a heater
` ` be involved?
` Make all the clothes out of teflon, then roast 'em at 300C to clean 'em.
` Oops! Problem with that. The fumes will kill your parrot, then where will
` you be?
No, afaik the fumes evolve at higher temp (400?, 600?).
Pete Vincent
Disclaimer: all I know I learned from reading Usenet.
Old May 16th 05, 03:32 PM
Rich S.
sez:
` ` be involved?
'em.
will
` you be?
No, 500° F (260° C). see http://tinyurl.com/cndss
Also http://www.parrotparrot.com/birdhealth/kola.htm
Aye, tis sad to see a pirate wi'out his parrot.
Rich "Arrr" S.
Old May 16th 05, 10:53 PM
Morgans
Sorry, wrong. The Teflon starts to break down at temps as low as 500
degrees *F* The previous poster was talking about temps in C.
The Teflon puts out tiny fibrous like stuff that floats through the air, and
while it kills Poly, it is none too good on humans, too. Since I have
birds, I have very little Teflon, and when it is used, I watch it like a
hawk. 500F is possible at the heat that barely burns bacon.
Old May 13th 05, 08:26 AM
Frank van der Hulst
Sheeshh... You're a *million* miles from any peeping tom... go nude!
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
Hubble plug to be pulled John Carrier Military Aviation 33 March 19th 04 04:19 AM
Rules on what can be in a hangar Brett Justus Owning 13 February 27th 04 05:35 PM
OT (sorta): Bush Will Announce New Space Missions Dav1936531 Military Aviation 0 January 9th 04 10:34 AM
Strategic Command Missions Rely on Space Otis Willie Military Aviation 0 September 30th 03 09:59 PM
