Sticking altimeter
Old November 5th 20, 08:46 PM posted to rec.aviation.soaring
Kenn Sebesta
Default Sticking altimeter
My altimeter in my AC-5M is sticking. It works fine when the engine is on or when you tap on the window, but otherwise when gliding it gets stuck up to 100' worth. I suspect that a rebuild will cost as much as a new one will, so I'd rather go the route of fixing it myself (or replacing it with something with added functionality).
Any suggestions on fixing it?
Mylar Not Sticking Gary Wayland Soaring 13 January 13th 19 07:10 PM
WTB: used 57mm Altimeter OR swap for 80mm Altimeter joesimmers Soaring 0 November 3rd 09 11:59 AM
Zen and the sticking RG-45 rod wright1902glider Home Built 5 February 20th 09 06:10 AM
Sticking yoke soxinbox Owning 15 February 28th 06 04:36 AM
STICKING YOUR NECK OUT? SelwayKid Piloting 4 January 3rd 04 12:13 AM
