LXNAV introduces New ADI Air Data Indicator
Old November 7th 20, 04:41 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Default LXNAV introduces New ADI Air Data Indicator
LXNAV
Indicates airspeed, altitude and vertical speed with an integrated high precision digital pressure sensors. The unit has standard dimension of 57 mm diameter. Not TSO.
Many features see
http://www.craggyaero.com/air_data_indicator.htm
Richard
www.craggyaero.com
Old November 7th 20, 05:48 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Richard Pfiffner wrote on 11/7/2020 8:41 AM:
LXNAV
Many features see
Richard
www.craggyaero.com
You have to read the manual to discover the vertical speed indicator can be used as a vario
(using electronic Total Energy compensation - no probe), or as a standard, uncompensated VSI.
No audio, but probably at least adequate as a backup to the primary vario. That makes it a
3-in-one combo: ASI, ALT, Vario. That's good news for small panels, and a lot cheaper, too.
Old November 7th 20, 06:27 PM posted to rec.aviation.soaring
John Galloway[_2_]
LXNAV
Many features see
Richard
www.craggyaero.com
Looks like an excellent concept but does it have any sort of approval? I can't see any mention one way or the other on the LX Nav website or in the manual.
Old November 7th 20, 07:07 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
John Galloway wrote on 11/7/2020 10:27 AM:
LXNAV
Many features see
Richard
www.craggyaero.com
Contact LXNav, as there are obviously a lot of aircraft that require certified instruments, and
they may be pursuing certification so they can also serve that market.
Old November 7th 20, 09:50 PM posted to rec.aviation.soaring
LXNAV
Many features see
Richard
www.craggyaero.com
No ETSO for the ADI at this time. I would say OK for experimental aircraft.
The Air Avionic ACD has a ETSO Altimeter and also controls Transponder/Transceiver.
Richard,
www.craggyaero.com
http://www.craggyaero.com/acd_altimeter.htm
Old November 7th 20, 09:57 PM posted to rec.aviation.soaring
LXNAV
Many features see
Richard
www.craggyaero.com
I may be wrong but I don't believe any of the Winter Instruments we see in gliders have ETSO certification.
Richard
Old November 7th 20, 10:12 PM posted to rec.aviation.soaring
Matthew Scutter
LXNAV
Many features see
Richard
www.craggyaero.com
Richard
They are ETSO, and they come new with a Form 1.
Old November 8th 20, 07:24 AM posted to rec.aviation.soaring
krasw
"A lot of aircraft" in this case would be every single glider in the world except US exp. reg gliders, I guess.
Old November 8th 20, 12:52 PM posted to rec.aviation.soaring
R[_4_]
On Saturday, November 7, 2020 at 11:41:56 AM UTC-5, Richard Pfiffner wrote:
LXNAV
Many features see
Richard
www.craggyaero.com
Makes me want a new glider. *️*️*️*️*️
Old November 8th 20, 02:38 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
krasw wrote on 11/7/2020 11:24 PM:
Sounds like a strong financial incentive to pursue certification! But, I don't really know what
they think their market is, which could include the US experimental airplanes. They obviously
think there is a decent market that made it worth developing the ADI, as does LX Navigation,
with it's similar "Iris all-in-one":
http://www.lxnavigation.com/iris-series/
The main differences between the two that I know about are ..
-The ADI offers an expanded scale at low speeds; the Iris does not (I'm told it's feature they
are working on)
-The ADI Vne can adjust with altitude; the Iris does not have that feature
-The ADI setup is done directly on the instrument; the Iris requires a $200 wifi adapter to
connect to a computer
-The Iris has a built-in backup battery; the ADI does not
LX Navigation Introduces the New LX 9090 Zeus Dave Springford Soaring 10 February 15th 12 05:04 PM
Craggy Aero Introduces the Ultimate Flight System Richard[_1_] Soaring 18 August 14th 08 04:56 AM
Rep Rangel introduces Draft Bill (for Iran?!): [email protected] Naval Aviation 17 June 5th 06 11:37 AM
AVSIM Introduces New List Server Tom Allensworth Simulators 4 July 12th 04 01:16 AM
Air Force Academy Introduces Sweeping Changes, Looks to Future Otis Willie Military Aviation 1 October 8th 03 07:40 PM
