midair in Bay Area Nov 7
Old November 9th 20, 05:51 PM posted to rec.aviation.soaring
Darren Braun
Default midair in Bay Area Nov 7
FYI, for those who hadn't heard.
https://www.asias.faa.gov/apex/f?p=1...-20,SCHLEICHER
Darren
Old November 9th 20, 06:11 PM posted to rec.aviation.soaring
Ramy[_2_]
Luckily both pilots were able to bail out. One pilot was injured and is recovering.
Ramy
Old November 9th 20, 08:30 PM posted to rec.aviation.soaring
Ramy
Ramy, what altitude did they collide and were they flying together? Bob
Old November 9th 20, 08:46 PM posted to rec.aviation.soaring
Ramy[_2_]
Around 5500 feet, 3500 AGL or so. They were not flying together per se, but were part of 8 gliders or so who flew from Byron that day in the same area on a great soaring day. That’s pretty much all I know so far. The bail out was captured by a photographer. You will need to zoom on the photos.
http://claycord.com/2020/11/07/repor...oygdc08p925lqs
Ramy
Old November 9th 20, 08:51 PM posted to rec.aviation.soaring
Ramy
Pretty lucky for the both of them, this could have been a real disaster for human loss. They need to go buy a lotto ticket. Bob
Old November 9th 20, 09:13 PM posted to rec.aviation.soaring
jfitch
Rumor has it that while both gliders were Flarm equipped, one was not functioning that day. Anybody know more?
Ramy
Old November 9th 20, 10:25 PM posted to rec.aviation.soaring
Ramy[_2_]
I can only confirm that one flarm was working since I could see him earlier.. He also had ADSB. I know the other glider was equipped with flarm but I don’t know if it was operative.
One of the gliders was my old ASW27.
Ramy
Old November 10th 20, 03:25 AM posted to rec.aviation.soaring
George Haeh
Flarm Antenna placement is critical on ASW-27s because of carbon fiber structure. A single antenna by the glareshield leaves a big blind spot below. After a close encounter with an ASW-28 below, I mounted antennas on both sides of the canopy. Unfortunately FCC does not allow transmit on both antennas.
Old November 10th 20, 04:39 PM posted to rec.aviation.soaring
Waveguru
I wonder if they were at least talking to each other? Ramy, were you hearing anything on the radio? Anyone else?
Boggs
Old November 10th 20, 08:24 PM posted to rec.aviation.soaring
Perhaps we should standardize on Rx+tx on top, rx only on bottom?
(Hoping there is a place in the wheel well without carbon fiber.)
Then at least you would have a certain path from the guy you can't see.
At Area 51, Plenty of Invaders, No Aliens - area 51.jpg Miloch Aviation Photos 0 September 21st 19 07:16 PM
Viral Area 51 ‘raid’ amasses 1 million recruits, gets Air Force warning - area 51.png (1/3) The 'Brightness' control still doesn't help Aviation Photos 0 July 16th 19 10:57 AM
Right seat NY area to Boca Raton area doylflier Piloting 0 May 30th 07 01:06 PM
Another midair! tango4 Soaring 3 April 27th 04 06:14 PM
Pix of two midair F-18s Pechs1 Naval Aviation 9 January 8th 04 02:40 PM
