Vans RV-6a diesel?
Old May 13th 05, 02:29 AM
Luke Scharf
Default Vans RV-6a diesel?
All of this diesel engine talk has me wondering -- has anyone built an
RV-6A with a Thielert engine or something similar?
Would the RV-6A be underpowered with the 120hp Centurion 1.7?
-Luke
Old May 13th 05, 02:31 AM
Dave S
-Luke
probably NOT underpowered, because my understanding is that this engine
is able to give equivalent thrust to a 180 hp gas engine. I am presuming
the difference is in the torque generated.
A jet-a Piston RV would be a wonderful accomplishment
Dave
Old May 13th 05, 03:17 AM
Luke Scharf
-Luke
I did a little more reading, and the centurion-engines.com site says
that they only approve of using the engine with a constant-speed prop.
If I'm thinking correctly, you get a benefit out of the extra torque
with a constant speed prop, because the prop can take a bigger bite of
air. OTOH, with the fixed-pitch props that I'm used to, the RPM sets
the amount of power (or is it thrust? I think it's power) that you get
out of it -- end of story.
Starting to make sense, I think.
-Luke
Old May 13th 05, 03:34 AM
Dude
"Dave S" wrote in message
.net...
-Luke
probably NOT underpowered, because my understanding is that this engine is
able to give equivalent thrust to a 180 hp gas engine. I am presuming the
Dave
I believe that they were planning to only offer the engine with an OEM
agreement from the Kit manufacturer. I have not seen any announcements as
to that changing, or them having a deal with Van's. I think Thomas Borchert,
who posts on here a bit who may know more.
The engine is heavier than the 0-360 and would need a special engine mount.
The RV's are all light enough that it would be plenty of engine though. I
have been thinking that an RV or a Lancair Legacy would be excellent with
this engine. You would likely get less climb, but you could likely higher
and much faster at altitude.
It's not as simple as most aircraft engines though, so you would need some
sort of course to do the maintenance. Your EAA buddies and fellow hangar
rat's ain't seen one of these before.
2-stroke diesel is the (near) future? Max Kallio Home Built 134 July 18th 05 12:39 AM
2-stroke diesel is the (near) future? Max Kallio Rotorcraft 123 July 18th 05 12:39 AM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 04:04 AM
Diesel Jodel information..........and .........diesel plane groups Roland M Owning 1 January 4th 04 04:04 AM
bulding a kitplane maybe Van's RV9A --- a good idea ????? Flightdeck Home Built 10 September 9th 03 07:20 PM
