WANTED: Trig Circular Hole Adapters
Old November 18th 20, 02:59 AM posted to rec.aviation.soaring
Default WANTED: Trig Circular Hole Adapters
I bought a used Trig TT22 transponder but it didn't come with the semi-circular mounting adapters ("circular hole adapters"). I need these as my install will be going into a round hole.
I am hoping that someone somewhere installed a Trig transponder (or Trig transceiver) into an oblong hole and thus has laying around an unused set of the mounting adapters that I could buy from them.
Please let me know.
Thanks, John (OHM)
Old November 18th 20, 03:01 AM posted to rec.aviation.soaring
Please let me know.
Thanks, John (OHM)
jhderosa at yahoo.com
Old November 18th 20, 04:46 AM posted to rec.aviation.soaring
cjl76
Hi John,
You would be welcome to have mine FOC but they're in my hangar which I'll have no access to for quite some time. Sorry!
Casey
B3
On Wednesday, 18 November 2020 at 11:01:41 am UTC+8, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Please let me know.
Thanks, John (OHM)
Old November 18th 20, 04:31 PM posted to rec.aviation.soaring
Casey,
Thanks for the offer. I won't be doing the install until the March time frame so I might take you up on your kind offer.
Short of finding these adapters I could just (temporarily?) use some aluminum plate to make a transition piece from the rectangular hole pattern of the control head to the square hole pattern of the 56mm round instrument cutout. The head wouldn't be flush to the panel face but, aesthetics aside, it would work. And how often do I even LOOK at the transponder anyway?
Old November 18th 20, 05:17 PM posted to rec.aviation.soaring
Dan Marotta
On 11/18/20 9:31 AM, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Casey,
John,
You could buy a hole plug very inexpensively and cut out what you don't
need. Or you could contact Trig...
Dan
5J
Old November 18th 20, 07:29 PM posted to rec.aviation.soaring
Basically what I was thinking of doing. Take a blank 57mm hole cover plate and drill a 57mm (2-1/4") hole in the middle of it. I would add rivnuts as I find myself flinging swear words at instruments that use loose nuts and bolts. Then drill and countersink the 4 rectangular spaced holes into the hole cover to attach the control head. Boom.
Old November 19th 20, 01:19 AM posted to rec.aviation.soaring
Michael Bamberg
On Wednesday, November 18, 2020 at 11:29:38 AM UTC-8, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
John,
I think I have two sets of the adapters, I'll look and send you a PM.
Mike B.
Old November 19th 20, 03:48 PM posted to rec.aviation.soaring
Michael Bamberg
John,
I do have two, I sent you an email. Let me know if you want one or both.
In wave, in blue hole at cloud level, hole closes, in IMC, then what? son_of_flubber Soaring 141 April 29th 15 03:51 AM
Worm Hole no Need for Black Hole Michael Baldwin, Bruce Products 2 May 8th 07 11:04 AM
lemo adapters? [email protected] Piloting 10 September 14th 05 02:59 AM
headset - cellphone adapters Helen Woods Piloting 4 March 28th 05 06:29 AM
LOW TO HIGH IMPEDANCE ADAPTERS Paul Millner Owning 1 July 5th 03 01:08 PM
