Cessna 404 Titan
Old June 20th 20, 05:52 AM posted to alt.binaries.pictures.aviation
Miloch
Default Cessna 404 Titan
https://en.wikipedia.org/wiki/Cessna_404_Titan
The Cessna Model 404 Titan is an American twin-engined, propeller-driven light
aircraft built by Cessna Aircraft. It was that company's largest twin
piston-engined aircraft at the time of its development in the 1970s. Its US
military designation is C-28, and Swedish Air Force designation Tp 87.
History
The Cessna 404 was a development of the Cessna 402 with an enlarged vertical
tail and other changes. The prototype first flew on 26 February 1975. It is
powered by two 375 hp/280 kW turbocharged Continental Motors GTSIO-520 piston
engines. Two versions were offered originally; the Titan Ambassador passenger
aircraft for ten passengers, and the Titan Courier utility aircraft for
passengers or cargo. By early 1982 seven different variants were available,
including a pure cargo version, the Titan Freighter. The Freighter was fitted
with a strengthened floor, cargo doors, and its interior walls and ceiling were
made from impact-resistant polycarbonate materials to minimize damage in the
event of cargo breaking free in-flight.
Role
Light passenger/cargo aircraft
Manufacturer
Cessna
First flight
26 February 1975
Introduction
1976
Status
in use
Produced
1976–1982
Number built
396
Developed from
Cessna 402
Variants
Cessna 441
Variants
Titan Ambassador – Basic 10-seat passenger aircraft.
Titan Ambassador II – Ambassador with factory fitted avionics.
Titan Ambassador III – Ambassador with factory fitted avionics.
Titan Courier – Convertible passenger/cargo version.
Titan Courier II – Courier with factory fitted avionics.
Titan Freighter – Cargo version.
Titan Freighter II – Freighter with factory fitted avionics.
C-28A Titan – Designation given to two aircraft purchased by the United States
Navy
Specifications (Ambassador I)
General characteristics
Crew: 2
Capacity: 6–8 passengers
Length: 39 ft 6 1/4 in (12.046 m)
Wingspan: 46 ft 8 1/4 in (14.230 m)
Height: 13 ft 3 in (4.04 m)
Wing area: 242.0 sq ft (22.48 m2)
Aspect ratio: 9.0:1
Empty weight: 4,816 lb (2,185 kg)
Max takeoff weight: 8,400 lb (3,810 kg)
Fuel capacity: 340 US gal (280 imp gal; 1,300 L)
Performance
Maximum speed: 267 mph (430 km/h, 232 kn) at 16,000 ft (4,900 m)
Cruise speed: 188 mph (302 km/h, 163 kn) (econ cruise) at 20,000 ft (6,100 m)
Stall speed: 81 mph (130 km/h, 70 kn) flaps down, power off
Never exceed speed: 274 mph (441 km/h, 238 kn) (Calibrated airspeed)
Range: 2,120 mi (3,410 km, 1,840 nmi)
Service ceiling: 26,000 ft (7,900 m)
Rate of climb: 1,575 ft/min (8.00 m/s)
Take-off run to 50 ft (15 m): 2,367 ft (721 m)
Landing run from 50 ft (15 m): 2,130 ft (650 m)
Cessna 152 pics 2 [2/6] - Cessna150BC-for comparison Cessna 150s produced before 1964, such as this 1962 Cessna 150B, had a straight tail and no rear window.jpg (1/1) Miloch Aviation Photos 0 February 8th 20 03:03 PM
Titan T-51 Low pass Glen in Orlando[_4_] Aviation Photos 6 January 27th 09 01:32 PM
Titan Tornado OtisWinslow Home Built 0 May 26th 05 08:26 PM
Soaring on Titan! C.Fleming Soaring 13 February 6th 04 08:41 PM
Titan T-51... wildcat Home Built 1 July 16th 03 10:36 PM
