Android Galaxy note device for xcsoar ?
Old November 24th 20, 12:51 PM posted to rec.aviation.soaring
MMOORE
Default Android Galaxy note device for xcsoar ?
What are people using for xcsoar and Android ?
I would like to try xcsoar but there are a ton of Galaxy note X devices. I am a little wary of purchasing a refurbished device nor sure of what model number is best.
The Note 'lite' devices are a little cheaper, then there is an A20 and an A10S priced under $200 ? I will not be using it as a phone.
M
Old November 24th 20, 03:50 PM posted to rec.aviation.soaring
Brian[_1_]
I use a Galaxy Tab A 7, it has as good of sunlight readability as I have seen in a tablet and works well. I use Tophat, but should work fine with XCSoar.
Brian
Old November 24th 20, 05:24 PM posted to rec.aviation.soaring
Moshe Braner
Brian
Some color tablets are better than others, but I use Tophat on an
ancient Nook e-reader, because to my eyes the purely reflective B&W
e-ink display is far better in sunshine than any color display.
The Nook does not have a built-in GPS receiver, so some sort of add-on
is needed. I've used an external GPS puck via USB (sometimes froze up),
and later grafted a small GPS module right onto a Nook, connecting to
its internal serial interface (worked well). My latest arrangement is
with a Nook into which I've grafted an RS232 interface chip for a wired
serial connection. It gets GPS - and traffic - data from a FLARM.
Works great. But all those (other than the USB puck) required delicate
DIY soldering jobs.
Old November 25th 20, 02:23 AM posted to rec.aviation.soaring
I've run XCSoar and Top Hat on a Galaxy Tab S2 7.0. Works great, optimal size, runs long without a recharge. 4+ hour flights by judiciously turning off the screen when it's not needed. Much longer if it's plugged into a charger of course.
Old November 25th 20, 07:07 AM posted to rec.aviation.soaring
Patrick (LS6-b EH)
I use a Galaxy S 5, no complaints.
https://photos.app.goo.gl/gAuPWQpLL45kC18YA
Old November 25th 20, 01:09 PM posted to rec.aviation.soaring
MMOORE
On Wednesday, November 25, 2020 at 2:07:16 AM UTC-5, Patrick (LS6-b EH) wrote:
Thanks, are you using the built in GPS or getting that data over BT via your LXNAV ?
Old November 25th 20, 03:57 PM posted to rec.aviation.soaring
krasw
I have Note 20 Lite and it does not have bright enough display for glider use. Tried with xcsoar.
Old November 25th 20, 04:29 PM posted to rec.aviation.soaring
Patrick (LS6-b EH)
Right now, paired via BT to my Nano (first season with my own glider), but working to integrate the S7 and Flarm. With Flarm bogies, I might think about going to a Note, but I don't fly IFR so don't want to be overwhelmed with the screen. My partner in the glider uses a Tab which I think is too big.
Just like the 3 bears - too small, too big, just riiiight...
Old November 26th 20, 05:36 AM posted to rec.aviation.soaring
Bret Hess
Galaxy Note 4 works great. And you can replace the battery easily.
Old November 26th 20, 03:29 PM posted to rec.aviation.soaring
MMOORE
Thanks, just ordered a Note 4.
iPhone 6+ or Galaxy Note 4? Duster Soaring 22 March 28th 17 12:23 AM
Getting Started with XCSoar on Android Thomas Van de Velde Soaring 0 January 27th 13 08:47 PM
5.7" Mirasol Android Device Craig Funston[_2_] Soaring 10 March 3rd 12 10:02 PM
XCSoar for Android Max Kellermann Soaring 1 April 21st 11 06:39 PM
XCSoar for Android Sean Fidler Soaring 6 March 21st 11 05:50 PM
