Airport Database
Old May 16th 05, 04:04 AM
Wizard of Draws
Default Airport Database
Does anyone know where I can lay my hands on an airport database with name,
ID, lat/long and elevation?
I've found two from separate sources that are close, but each is missing at
least one element that I'd like to have and I don't relish the thought of
trying to merge them into one.
Jeff 'The Wizard of Draws' Bucchino
Cartoons with a Touch of Magic
http://www.wizardofdraws.com
More Cartoons with a Touch of Magic
http://www.cartoonclipart.com
Old May 16th 05, 04:37 AM
Ben Hallert
airnav.com has one, as does landings.com.
Old May 16th 05, 04:48 AM
Toks Desalu
Are you a member of AOPA?
If not, you should!
By the way, they have have the aiport directory. They have everything you
need, every detail to the bone. You can even download airport directory to
the PDA. You can't beat that, unless you have the array of expensive
equipment in your plane.
Toks Desalu
PP-ASEL
"Dyin to soar!"
"Wizard of Draws" wrote in
message news:BEAD8615.6E996%jeffbTAKEOUTALLCAPS@TOEMAILwiz ardofdraws.com...
name,
at
Old May 16th 05, 10:33 AM
Christian
For data, check out http://www.sarangan.org/aviation/garmin/ and also
http://navaid.com/GPX/
http://www.cockpitgps.com/ gives a good introduction to use of handhelds...
Regards from ENZV
name,
at
Old May 16th 05, 12:21 PM
Paul Tomblin
GPX might be a bit hard to parse, but with the help of GPSBabel
( http://gpsbabel.sourceforge.net/ ), you can turn that GPX file into a
CSV (comma separated values) or other standard ascii file that you can
import into Excel or whatever you want to do with it.
Disclaimer: "These opinions are my own, though for a small fee they can be
yours too."
Old May 16th 05, 01:23 PM
Larry Dighera
On Sun, 15 May 2005 23:04:53 -0400, Wizard of Draws
wrote in
BEAD8615.6E996%jeffbTAKEOUTALLCAPS@TOEMAILwizardo fdraws.com::
Of course, UNIX contains the ideal tool for merging databases and
manipulating fields within a database: awk. And there's even an awk
executable for Windows available he
http://cm.bell-labs.com/cm/cs/awkbook/index.html
or
http://cm.bell-labs.com/cm/cs/who/bwk/
And you'll find a manual page for awk he
http://www.mkssoftware.com/docs/man1/awk.1.asp
Old May 16th 05, 02:03 PM
Andrew Sarangan
Wizard of Draws wrote in
news:BEAD8615.6E996%jeffbTAKEOUTALLCAPS@TOEMAILwiz ardofdraws.com:
name, ID, lat/long and elevation?
missing at least one element that I'd like to have and I don't relish
the thought of trying to merge them into one.
The most complete raw data is http://aviationtoolbox.org/raw_data/FAA/ATA-
100/
Old May 16th 05, 02:40 PM
name,
missing at
thought of
Cartoons with a Touch of Magic=81
More Cartoons with a Touch of Magic=81
DAFIF
https://164.214.2.62/products/digitalaero/index.cfm
it's what most PC based flight planners, simulators, etc... run off of
Old May 17th 05, 02:20 AM
Wizard of Draws
On 5/16/05 7:21 AM, in article , "Paul
Tomblin" spewed:
Thanks guys. This looks like my best bet since I'm on a Mac. I just need a
basic CSV file to import into my Filemaker Pro logbook. I'm trying to learn
the program and a logbook with flight time, currencies, insurance and
medical info, E6B and airports seemed like a useful way. Since I'm not that
good with math, my head hurts.
WI airport closure Mike Spera Owning 0 March 9th 05 01:53 PM
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 05:12 AM
N94 Airport may expand into mobile home community, locals supportive William Summers Piloting 0 March 18th 04 03:03 AM
Rules on what can be in a hangar Brett Justus Owning 13 February 27th 04 05:35 PM
