Cessna 210 V-Speeds
Old May 17th 05, 04:30 AM
Eric Bartsch
Default Cessna 210 V-Speeds
I'll be taking my first dual in a 1974 Cessna 210II this Sunday and I
won't have access to a POH until then. If anyone could post the
V-Speeds and typical traffic pattern speeds, I'd appreciate it so I can
start a bit of studying in advance.
Also, any words of wisdom about the plane would be great. I've flown a
206 and a 172RG a lot, so I'm visualizing a combination of the two
(probably not very accurate).
Eric
Old May 17th 05, 05:08 AM
Jose
I flew a 210 once. It took off like a rocket. (My previous high
performance experience at the time was a Cutlass)
The cutlass is a really nice plane - too bad they stopped making them.
I don't know how a 206 handles, maybe the 210 won't seem so unusually
powerful to you.
Jose
Money: what you need when you run out of brains.
Old May 17th 05, 07:01 AM
John Clonts
"Eric Bartsch" wrote in message
Hello Eric,
I have a '79 210.
All speeds in knots
Vx about 95
Vy 65-70
Vso 50-55
Best glide 70-80
Maneuvering speed 110-120
IFR
Approach level no flaps 130-140 (gear up, about 18")
Approach level w/flaps 110
VFR
Pattern 100-110
Turn Final about 90
Over the fence 65-70
Cruise 160, 80 pounds per hour
Definitely a heavier feel overall than a 172 It will really drop a wing in a departure stall. People told
me that it was "nose heavy" in the flare, but I never found that to be the case.
That's all I can think of at this hour, except that it's a great plane overall, we love ours.
Cheers,
John Clonts
Temple, Texas
N7NZ
Old May 17th 05, 07:09 AM
John Clonts
"John Clonts" wrote in message ...
Hello Eric,
I have a '79 210.
All speeds in knots
Vx about 95
Vy 65-70
Ooops, better flip those Vx and Vy speeds!
Old May 17th 05, 08:13 PM
john smith
Are those gear-up or gear-down speeds?
(Gear down speeds are slower than gear up speeds)
John Clonts wrote:
I have a '79 210.
All speeds in knots
Vx about 95
Vy 65-70
Old May 17th 05, 09:21 PM
Mortimer Schnerd, RN
Vle and Vlo are both 140 KIAS on the C-210. With gear down and with 10° of
flap, best angle is 72 knots; best rate 80 knots. Retract the gear once
obstacles are cleared, then the flaps after you accelerate through 80 knots.
Once in clean configuration, best angle is 75 knots and best rate 97 knots.
VE
Old May 18th 05, 02:33 AM
John Clonts
"Mortimer Schnerd, RN" wrote in message
. com...
Vle and Vlo are both 140 KIAS on the C-210. With gear down and with 10° of flap, best angle is 72 knots;
best rate 80 knots. Retract the gear once obstacles are cleared, then the flaps after you accelerate through
80 knots. Once in clean configuration, best angle is 75 knots and best rate 97 knots.
My manual agrees on the best angle 72 (at MGW, 3800 lbs) as listed in the Takeoff Distance table; and agrees
with the clean 97 knots best rate in the Rate of Climb table. But I don't see any specific reference for best
rate dirty of 80 or best angle clean of 75. Does your manual specify that? Or are you just citing your
experience and practices?
Cheers,
John Clonts
Temple, Texas
N7NZ
Old May 17th 05, 11:14 AM
in a departure stall. People told me that it was "nose heavy" in the flare,
Flying a C-210 is good training for flying a C-402. Elevator forces are very
similar and much heavier than the C-172. That being said, it's a very capable
airplane.
I had access to both normal C-210s and we had one with a Robertson STOL kit
installed. *That* was a beast. V speeds were virtually identical to the
C-172's and a full STOL takeoff involved pulling it off at 42 knots with your
right leg quivering under a load heavier than a Vmc demonstration in the C-402.
Absolutely incredible! No mush even at the slower speeds. Normal takeoff in
the STOL bird was at 60 knots. I used 80 knots in the conventional C-210.
We had a three plane trip from Marsh Harbour, Bahamas to St. Lucie County, FL
once. I was in an ordinary C-210, the other two aircraft were a T-210 and a
Turbo Aztec. We all landed within 5 minutes of one another. I burned 19
gallons, the T-210 burned 26 gallons and the Turbo Aztec burned 59 gallons of
fuel! You just can't beat a C-210 for bang for the buck.
And for what it's worth: a fully loaded C-210 sinks clean at about 700 fpm with
the engine out. Don't ask me how I know this. To compare, a Piper Lance sinks
at 1100 fpm under the same conditions. Don't ask me how I know that, either.
I can see why. The 210 is one hell of an airplane.
VE
1/72 Cessna 300, 400 series scale models Ale Owning 3 October 22nd 13 03:40 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Piloting 1 November 4th 03 12:57 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Products 1 November 4th 03 12:57 AM
Cessna 337C Speeds Al Piloting 1 August 20th 03 05:36 PM
