50mm Hitch Ball
Old May 17th 05, 12:12 AM
John Scott
Default 50mm Hitch Ball
The following company is now selling 50mm Hitch Balls for $19.95 plus
shipping. You can order via their web site. I am not affiliated with them,
but I did just buy a hitch ball from them.
The Hitch Corner
10677 W. Centennial Rd. #103
Littleton, CO 80127
Metro Denver Area - 303-904-1558
Toll Free - 1-877-66HITCH (664-4824)
Hours: M-F 8-5 (MST)
Sat 8-12 noon (MST)
www.hitchcorner.com
John Scott
Old May 17th 05, 05:09 AM
A two inch ball equals 50.8 mm. I would think that would be close
enough for most applications. Two inch balls are a lot cheaper.
Clay Thomas
with them,
The Hitch Corner
Littleton, CO 80127
Sat 8-12 noon (MST)
www.hitchcorner.com
John Scott
Old May 17th 05, 02:09 PM
Tony Verhulst
My club has a factory L23 trailer and a 2 inch ball will not fit. The 50
mm ball (for which it was designed) works fine. I've heard of other
cases as well.
Tony V.
Old May 17th 05, 06:36 PM
Eric Greenwell
You would think it would work, but in most cases it won't.
They often won't go on, or if they do, they jam. Turning
them down is also a real pain.
And in the worst case, the jamming causes the ball to loosen during
turns (US hitches used a bolted on ball, unlike the European hitches
I've seen).
Eric Greenwell
Washington State
USA
Old May 17th 05, 07:18 PM
Marc Ramsey
Well, I have to admit that I had been using 1 7/8 inch (47.6mm) balls
with 50mm hitches for many years and thousands of miles, without a
single problem. Oddly enough, I can across an auto parts store a few
years back that was selling "2 inch" balls, which were clearly embossed
"50mm", so I now have one that is the "right" size...
Marc
Old May 17th 05, 07:30 PM
Eric Greenwell
Eric Greenwell wrote:
And in the worst case, the jamming [of a 2" ball in a 50mm hitch]
causes the ball to loosen during turns (US hitches used a bolted on
ball, unlike the European hitches I've seen).
Ouch - that I haven't seen, but can easily believe. I hope it's not
something learned from direct experience?
Fortunately, no, but was related to me many years ago when I had Libelle
trailer (Eberle?) with a 50 mm hitch, and was thinking of getting by
with a 2" ball. Those older trailers were more likely to come with 50 mm
couplers. They typically couldn't be changed, or at least with great
difficulty, so getting the proper ball was the best solution. The newer
trailers all seem to come properly equipped for the USA.
Eric Greenwell
Washington State
USA
Old May 18th 05, 06:21 AM
The Hitch Corner also sells Convert-A-Ball products and they offer a
50mm ball but don't advertise it. I have Convert-A-Ball 1 7/8", 50mm
and 2" balls and 3/4" and 1" shanks so I am set to tow every trailer I
have with easy convertibility. Convert-A-Ball products can be ordered
directly at http://hitchballs.com
Steve
with them,
The Hitch Corner
Littleton, CO 80127
Sat 8-12 noon (MST)
www.hitchcorner.com
John Scott
Old May 18th 05, 06:28 AM
Steve
with them,
The Hitch Corner
Littleton, CO 80127
Sat 8-12 noon (MST)
www.hitchcorner.com
John Scott
Ball vario overhaul? Anthony Turiano Soaring 6 June 17th 09 08:06 PM
wanted L'Hotellier ball fitting assembly Udo Rumpf Soaring 3 January 7th 05 03:05 AM
Eye Ball Vent B. Iten Soaring 4 September 4th 04 09:38 AM
Ball 100 Vario Repair? Bob Johnson Soaring 0 August 19th 04 03:27 PM
Trailer hitch inadvertant disconnect Bill Daniels Soaring 5 July 16th 04 03:17 AM
