Libelle repair near Cambridge UK?
Old December 14th 20, 12:28 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default Libelle repair near Cambridge UK?
I need to replace an airbrake bearing in my early Std Libelle 201 before
getting annuals done for next season.
Any recommendations for somebody who can tackle this job would be
appreciated.
Martin | martin at
Gregorie | gregorie dot org
Old December 14th 20, 01:29 PM posted to rec.aviation.soaring
Matthew Scutter
appreciated.
Martin | martin at
Navboys at Lasham.
Old December 14th 20, 08:02 PM posted to rec.aviation.soaring
john firth
appreciated.
Martin | martin at
Navboys at Lasham.
How about Andrew Hume? His father was a glider repair guy; maybe Andrew is too.
He has a pIK 20 E
jmf
Old December 18th 20, 01:40 PM posted to rec.aviation.soaring
Hank Nixon
appreciated.
Martin | martin at
Are you talking about the gear box at the root that can get tight over time?
UH
Old December 18th 20, 02:53 PM posted to rec.aviation.soaring
before getting annuals done for next season.
appreciated.
Martin | martin at Gregorie | gregorie dot org
time?
No. This is an early Std Libelle with upper and lower surface airbrakes.
The top surface bearing nearest the root got corroded when the wing cover
on that wing leaked. The rest seem fine.
Martin | martin at
Std. Libelle vs Club Libelle [email protected] Soaring 10 August 21st 19 01:00 AM
ClearNav Instruments - Cambridge Repair Service - July KiloKilo[_2_] Soaring 8 July 5th 15 12:41 AM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
Cambridge Aero: Repair Situation Update Chip Bearden Soaring 2 October 2nd 03 06:56 PM
Cambridge repair in the UK? Ian Johnston Soaring 1 July 21st 03 09:20 AM
