Welding equipment advise
Old May 17th 05, 05:49 PM
PittsS1C
Default Welding equipment advise
I am gathering the things I need to start building.
Does anyone here have any experience with the portable oxy acetylene setups?
Is the typical 20ft^3 Oxygen and 10 ft^3 acetylene configuration too small
to be useful when building a fuselage/struts?
How many times will you typically have to refill during the building process
with these smaller tanks?
Thanks
Old May 18th 05, 01:27 AM
_
"PittsS1C" wrote in message
setups?
small
process
Thanks
I'd take this next door to sci.engr.joining.welding NG and they'll be able
to help you there.
Larry
My turbine powered boat project
http://www.weldingfaq.com/turbine2.asp
Old May 18th 05, 01:55 AM
Bertie the Bunyip
"PittsS1C" :
setups?
small to be useful when building a fuselage/struts?
process with these smaller tanks?
Thanks
Depends on how much practice you do before you start on the fuselage. You
could definitely build a whole fuselage of a Pitts with that acetylene tank
alone and maybe one or two oxy refills.
Bertie
Old May 18th 05, 02:19 AM
Rich S.
setups?
No help with the tanks, but you can type the "³" by holding ALT while you
key in 0179 using the number pad.
Ref: Typing diacritics and special characters at
http://www.forlang.wsu.edu/help/keyboards.asp
Rich "Not €" S.
Old May 18th 05, 02:42 AM
Ernest Christley
Thanks
I'm nearly finished with the welding of a Dyke Delta. You can see
pictures at http://www.ernest.isa-geek.org If your only going to build
one airplane at a time, I can tell you straight up that you want to get
the smallest bottles you can find. The ability to move it around
without grunting easily trumps the few trips you'll make to the welding
shop (someplace you'll want to go anyhow...at least when the wife's not
looking 8*) Except for a few thick pieces, most of the tube is so thin
that your flame resembles what can be had from a Bic lighter (I'm
exagerating, but not a whole helluva lot). I keep looking at that
little set that Harbor Freight has with the little plastic carrying case.
Also, get the lightest hose you can find. It won't alwsays be
convienent to put the fuselage in the perfect position, meaning you have
to support the weight of that hose in and awkward position. Always try
to avoid that, but the lighter hose is a godsend when you can't.
This is by far the hardest lesson about freedom. It goes against
instinct, and morality, to just sit back and watch people make
mistakes. We want to help them, which means control them and their
decisions, but in doing so we actually hurt them (and ourselves)."
Old May 18th 05, 07:38 PM
acetylene
setups?
too
building
No help with the tanks, but you can type the "=B3" by holding ALT
while you
=20
Or he could convert to liters...
--=20
FF
Old May 18th 05, 08:42 PM
Rich S.
I'd advise doing the welding before having a few liters. . .
Rich S.
Must the PLANE be IFR-equipped to fly over17,500? john smith Home Built 11 August 27th 04 02:29 AM
Equipment List Required Documentation O. Sami Saydjari Owning 9 April 21st 04 02:57 AM
Flying when you know there is something wrong with the plane C J Campbell Piloting 26 January 14th 04 04:38 PM
TIG welding video? Russell Duffy Home Built 3 October 6th 03 05:55 AM
Welding techniques for 4130? Building The Perfect Beast Home Built 29 September 4th 03 08:52 PM
