411 413 inspection question
Old May 17th 05, 11:46 PM
A Lieberman
Default 411 413 inspection question
Unpleasant surprise on my .411 .413 check.
Person doing the check would not certify the inspection. He said that the
VSI is not connected to the pitot static system.
I am the first to say I am clueless about "systems". He said I would have
to take it to a certified repair place to get it fixed.
The VSI works, so I don't get this at all.
It passed 2 years ago, with no problems. Do things "disconnect" on it's
own or what's up with my VSI. Everything else appears to work just fine
(ASI, altimeter and VSI).
My plane does not have an alternate static in the plane.
What should I expect when I take it to a repair center?
Allen
Old May 17th 05, 11:55 PM
Mark Hansen
Works, or appears to work. If it were not connected to the static source,
wouldn't it simply vent to the area behind the panel?
Allen
Mark Hansen, PP-ASEL, Instrument Student
Sacramento, CA
Old May 18th 05, 12:54 AM
A Lieberman
Mark,
I plan to fly tomorrow to the practice area. What I am planning to do is
time the climb rate to see if it is registering correctly (I.E climb or
descend at 500 per minute).
I flew last week in IMC doing some ILS approaches in actual conditions and
I truly did not notice anything unusual about the VSI.
Like I said, I don't know anything about systems, other then when something
doesn't work, to get it to the repair shop and get it fixed.
As far as I knew before today, everything worked perfectly, so I was not
expecting any problems.
Allen
Old May 18th 05, 03:38 PM
Mark Hansen
Mark,
If the VSI is vented to the cabin, you won't notice much of a difference.
Unless the cabin is pressurized, the air pressure will be slightly lower
than the actual static air pressure (from outside the cabin). However, when
you climb, the VSI will still show a climb, and at virtually the proper
rate.
Using the cabin air pressure as an "alternate" static source for the VSI
is fine in an emergency.
Even thought you don't notice a problem, given that someone found that it is
not connected up properly, you should take this as a problem that needs
to be fixed ;-)
Allen
Sacramento, CA
Old May 18th 05, 01:28 AM
Mike Ferrer
"A Lieberman" wrote in message
Interesting point. Although the VSI should be connected to the static
system, it is not required by 91.411 or FAR Appendix E. In other words, he
could have certified the system and you could have had an A&P investigate
why the VSI wasn't hooked to the static system afterwards.
The VSI will operate even though it is not connected the the official static
system. However, it should be fixed.
Old May 18th 05, 02:00 AM
A Lieberman
Can an A&P work on the static system? Again, you are talking to a real
newbie even though I have owned the airplane for 2 1/2 years, so please
excuse the questions due to my ignorance.
If this is such the case, why should it be hooked into the static system?
It seems to work good the way it is.
Also, one less instrument subject to failure should the pitot static system
go belly up?
Whatever the case, I want the plane to be as reliable as possible.
Allen
Old May 18th 05, 12:15 PM
Ron Natalie
Yes, but it takes a repair facility who can do the appropriate tests to
recertify the plane for IFR after most static system work.
Old May 18th 05, 08:34 PM
Mike Ferrer
No, a mechanic with an Airframe rating can certify the static system after
it has been worked on. For a non-pressurized aircraft, the test involves
sucking the static system up 1,000 ft and making sure it doesn't leak more
that 100 fpm. If no work was performed on the transponder or blind encoder,
it doesn not require IFR recertification.
Old May 19th 05, 03:32 PM
Don Hammer
This would apply to a VFR aircraft only. If you open the system on an
IFR aircraft, the 91.411 required part 43 altimeter tests will have to
be done by a rated entity; an "A" rated mechanic is not one of them.
IFR or VFR aircraft, if the transponder integrated system is disturbed
so as to cause an error, the 91.413 Part 43 tests must be re-done by a
rated entity. Will opening a static line that includes the
transponder quailfy as that kind of disturbance? Most FAA PMI's I
have delt with think so.
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old May 18th 05, 03:40 PM
Mark Hansen
But if the VSI is not connected to the static system, what has happed
to the point where it was connected? Is the static line simply venting
to the area behind the panel? Won't this affect all the other static-based
instruments?
.... unless someone took the time to plug the hole in the static line...
Sacramento, CA
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Home Inspection Listings Patrick Glenn Home Built 4 April 26th 04 11:52 AM
100 Hour Inspection Question FryGuy General Aviation 59 November 19th 03 04:01 AM
100 Hour Inspection Question FryGuy Piloting 58 November 19th 03 04:01 AM
