Ventus 2c gas spring
Old December 15th 20, 07:15 PM posted to rec.aviation.soaring
BobWa43
Default Ventus 2c gas spring
Does anyone have experience replacing the gas spring that supports the instrument panel in the Ventus2c? Any information on the specifications of the spring any difficulties encountered in replacing it will be greatly appreciated.
Old December 16th 20, 05:14 AM posted to rec.aviation.soaring
GliderCZ
Definitely a pain in the butt. The far end is difficult to reach. Adjust your rudder pedals to minimize their interference with the limited room available. Use a ratcheting box wrench to remove/replace the hardware. Sorry, don't remember the spring specs and can't find any documentation.
Old December 16th 20, 12:32 PM posted to rec.aviation.soaring
Mark Mocho
There is a possibility that the far end fitting can be left in place and the existing gas strut rod end can be unscrewed from the fitting, allowing you to just screw in the new one. The ASW-20 and Pegase canopy gas springs can be replaced using this method.
Old December 16th 20, 01:40 PM posted to rec.aviation.soaring
Jay Campbell
Replaced the strut on a Ventus 2b and agree with both above. I removed the entire spring, exchanged fittings outside the cockpit, re-installed. A little knuckle-busty but not too bad. Got the factory spring because Heinz had one in inventory. ) But he is now retired, I believe.
Old December 18th 20, 05:46 AM posted to rec.aviation.soaring
GliderCZ
Garret Willet is now the U.S. Schempp-Hirth rep, at Yankee Composites, Warner Springs, CA. He took on all or most of Heinz' inventory, I believe.
http://www.yankeecomposites.com/
Old December 18th 20, 06:06 PM posted to rec.aviation.soaring
BobWa43
Thanks to all who replied.
Old March 20th 21, 04:03 AM posted to rec.aviation.soaring
Armand Charbonneau
Does anyone have the spec for this shock? I need to replace the one on my Ventus 2c.
Old March 20th 21, 05:29 PM posted to rec.aviation.soaring
Dan Marotta
If your Ventus is an Experimental, look for identifying marks on the
shock and then cross reference it to an automotive part. You can bet SH
did not design and build their own...
Dan
5J
Old March 21st 21, 02:01 PM posted to rec.aviation.soaring
Randy Acree
Dan
LS Technologies Canada. They can make anything you want. I have used them for Cobra trailer struts after I waited for over 3 months for them from Cobra. Had them in a week. Knowledgeable and helpful.
http://lstechnologies.ca/
Randy AV8
Old March 22nd 21, 02:52 AM posted to rec.aviation.soaring
5Z
Two pair were installed on Cobra trailers at El Tiro this weekend.
5Z & WA
PW5 canopy gas spring Gabriel Canas Soaring 3 February 10th 20 06:14 PM
Ventus 2cxa instrument panel gas spring needed Ken Sorenson Soaring 6 January 10th 20 07:22 PM
Canopy gas spring LS4, USA [email protected] Soaring 3 October 30th 12 12:01 PM
Ventus 1 - anyone have experience w/o aileron centering spring? Gary Emerson Soaring 0 November 1st 08 02:36 PM
TOST Tow Spring Pad for Cub [email protected] Soaring 0 January 21st 08 04:08 AM
