Source for tail wheels
Last winter I had the tail skid of my Mini Nimbus replaced with a tailwheel
unit supplied by Schempp. It used a rollerblade (?) wheel with a solid polyurethane tyre on a plastic hub with two ball-bearings. After ten landings the hub was cracked and shedding parts and essentially wrecked I manged to find a replacement unit with a lightweight aluminium hub which appears to be holding up well. Trouble is, I found it in the trash can of a sports shop and no one could tell me the source. Anyone out there know where to purchase rollerblade/microscooter wheels with metal hubs - I'd sure like to have a spare. |
Do what I did... go to a local shop that specializes in rollerblades or
skateboards. Find the pimplefaced 14 year old kid that is working there and explain what you are looking for. Tell him that you need it for your glider and the parameters that you need: size, weight, acceleration to about 50 mph instantly. After he says "Cool", "Far out", "Sweet", "Tight", "Bad enough", or whatever the current lingo is, you will know that you found the correct person to help you. He will know _everything_ that is available and will know where to find it. Chances are that he will have a couple of slightly used ones sitting in the back that he will give you for nothing... maybe even press a couple of super-duper high speed bearings into them for you. BTW, acetone will take the psychedelic colors or flames off the side of the wheels... if you want to remove them! :-) Larry "Simon" simonchangetoatsymbolleswaddells.ch wrote in message news:simonchangetoatsymbolleswaddells.ch: Last winter I had the tail skid of my Mini Nimbus replaced with a tailwheel unit supplied by Schempp. It used a rollerblade (?) wheel with a solid polyurethane tyre on a plastic hub with two ball-bearings. After ten landings the hub was cracked and shedding parts and essentially wrecked I manged to find a replacement unit with a lightweight aluminium hub which appears to be holding up well. Trouble is, I found it in the trash can of a sports shop and no one could tell me the source. Anyone out there know where to purchase rollerblade/microscooter wheels with metal hubs - I'd sure like to have a spare. |
Or just go to any large sports store, and look in the rollerblade
section. They will have a variety of replacement wheels, bearings, axles for sale. I went for the biggest rollerblade wheel I could find, and the hardest (it is designed for street hockey, I think). The ones I got came with nice sealed bearings and screw-in axles, all I had to do was open up the axle bolt holes in my tailskid (just enough to remove the threads) and the new wheel fit perfectly after I cobbled up a couple of small bushings. These wheels lasted several seasons in the desert with little damage - while the previous softer rollerblade wheels I used "chunked" pretty badly after one season. Plus they are a nice orange color that matches the hi-vis trim on my glider! 66 |
I've visited plenty of these stores (in as much as that is possible in
Switzerland!) but all the new wheels I've found have plastic hubs - I'm looking for rmetal. I found one used metal one - with a hard rubber tyre but no maker's mark - which is doing fine so far. Plastic didn't last a season last year wrote in message oups.com... Or just go to any large sports store, and look in the rollerblade section. They will have a variety of replacement wheels, bearings, axles for sale. I went for the biggest rollerblade wheel I could find, and the hardest (it is designed for street hockey, I think). The ones I got came with nice sealed bearings and screw-in axles, all I had to do was open up the axle bolt holes in my tailskid (just enough to remove the threads) and the new wheel fit perfectly after I cobbled up a couple of small bushings. These wheels lasted several seasons in the desert with little damage - while the previous softer rollerblade wheels I used "chunked" pretty badly after one season. Plus they are a nice orange color that matches the hi-vis trim on my glider! 66 |
Or you may end up doing what I did.
After two seasons of struggling with that tiny gottverdampten rollerskate wheel at the tail of my LS-4 during which I aborted a number of launches because the wheel got twisted and steered me off the runway, I installed a full-sized tail wheel in a nicely faired cowling. Now my glider tracks and handles beautifully. I'm a happy camper. |
Where did you get the Fairing and wheel? I have an LS-6 and will be
needing to replace my Rollerblade wheel. Thanks! Jerz |
The wheel in my glider's tail skid lasts for many years and is made by
this compay: http://www.darnell-rose.com/catalog/index.htm Click on wheels and look for Extra Soft EZ Roll. The wheel on my glider is marked X-12-R. There are dealers locally or online. SP Simon wrote: Last winter I had the tail skid of my Mini Nimbus replaced with a tailwheel unit supplied by Schempp. It used a rollerblade (?) wheel with a solid polyurethane tyre on a plastic hub with two ball-bearings. After ten landings the hub was cracked and shedding parts and essentially wrecked I manged to find a replacement unit with a lightweight aluminium hub which appears to be holding up well. Trouble is, I found it in the trash can of a sports shop and no one could tell me the source. Anyone out there know where to purchase rollerblade/microscooter wheels with metal hubs - I'd sure like to have a spare. |
The wheel in my glider's tail skid lasts for many years and is made by this compay: http://www.darnell-rose.com/catalog/index.htm Click on wheels and look for Extra Soft EZ Roll. The wheel on my glider is marked X-12-R. There are dealers locally or online. The Darnell site doesn't have information on the wheels (amazing, huh? Just a picture of the wheel), and I couldn't find a site that did. Do you have an online dealer web site you can give us? -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Similar Threads | ||||
Azusalite wheels | Fred the Red Shirt | Home Built | 7 | July 12th 04 11:15 PM |
A Remote Compass- java source | [email protected] | General Aviation | 0 | July 3rd 04 06:39 PM |
Cambridge Aero Explorer Source Code Available. | Guy Byars | Soaring | 9 | May 20th 04 08:58 AM |
McCaully wheels & brakes available | Roger Long | Owning | 0 | March 4th 04 02:19 PM |
Winscore source code now available | Guy Byars | Soaring | 0 | February 5th 04 10:43 AM |
