Touch Up White Paint
Old May 21st 05, 02:10 AM
O. Sami Saydjari
Default Touch Up White Paint
I just noticed an area of exposed aluminum on my wing root, about the
size of a quarter. I am not sure how and when it got there. Exposed
aluminum seems like an inherently bad thing. Is there some good way to
do a do-it-yourself job of touching this up that is both effective at
protecting the wing and looks decent? My wing is white.
-Sami
N2057M, Piper Turbo Arrow
Old May 21st 05, 01:22 PM
Clay
Touch it up just like you would a car..
Make sure you use the same type and color of paint.
If it is a very small area, use a paper match or an air brush.
Old May 21st 05, 05:11 PM
Tom Jackson
This may help a little in matching color. I have a '74 Warrior, and the
white paint code (in Dupont Imron) is Juneau white H7848U.
The color can be cross-referenced into other types of paint by a local paint
dealer.
"O. Sami Saydjari" wrote in message
I just noticed an area of exposed aluminum on my wing root, about the size
of a quarter. I am not sure how and when it got there. Exposed aluminum
seems like an inherently bad thing. Is there some good way to do a
do-it-yourself job of touching this up that is both effective at protecting
-Sami
Old May 22nd 05, 01:29 AM
Michelle P
Sami,
Need to answer what caused the paint to come off in the first place.
Impact? Corrosion? Touch up is simple. If you use spray products mask
off all the windows on that side.....
Michelle
to do a do-it-yourself job of touching this up that is both effective
at protecting the wing and looks decent? My wing is white.
-Sami
Old May 23rd 05, 03:49 AM
O. Sami Saydjari
Well, but how do I actually matach the paint color on my arrow? When
you say "local paint dealer", do you mean any local paint dealer (house
paints, etc.)...or does one have to go to an aviation paint dealer
(which we do not have in town)? What type of paint do I ask for?
-Sami
dealer.
-Sami
Old May 23rd 05, 05:06 AM
George Patterson
Take an inspection cover plate off, clean it well, and take it to an auto paint
dealer (look in the phone book). They'll get you a close match.
George Patterson
"Naked" means you ain't got no clothes on; "nekkid" means you ain't got
no clothes on - and are up to somethin'.
Old May 23rd 05, 02:14 PM
Stealth Pilot
On Mon, 23 May 2005 04:06:43 GMT, George Patterson
ahhh white paint.
did you know that there are 3,267,984 shades of white paint and they
all look different when sprayed beside or over each other.
I've got 7 shades of white paint on my aircraft.
.....and they're all white white :-)
Stealth Pilot
Old May 29th 05, 02:25 PM
O. Sami Saydjari
After talking to a mechanic about this, he suggested that it was likely
that the small spot was improperly primed when it was last painted. He
also said that he has *never* been about to get an exactly match to
white....and that with fading, even if it matches at first, it wont
match after a year. He suggested getting spray paint (enamel) from the
hardware store with a white that best matches to my eye...and then spray
paint it with some feathering into the surrounding area. Does anyone
think this is not a good idea?
-Sami
Michelle P wrote:
Sami,
Michelle
-Sami
Old May 29th 05, 04:30 PM
Stealth Pilot
On Sun, 29 May 2005 08:25:58 -0500, "O. Sami Saydjari"
-Sami
appliance white is used everywhere in just this way. :-)
I have a friend with a Thorp T18 who swears he will repaint in rattle
can white enamel so that he can touch up the paint easily before
flyins.
Stealth Pilot
Old May 29th 05, 09:20 PM
Kyle Boatright
white....and that with fading, even if it matches at first, it wont match
after a year. He suggested getting spray paint (enamel) from the hardware
store with a white that best matches to my eye...and then spray paint it
with some feathering into the surrounding area. Does anyone think this is
not a good idea?
-Sami
Depending on how nice your airplane is, I'd pass on your mechanic's advise.
*Good* custom automotive painters can match almost any paint, and can blend
in the new paint well (or mask back to the next panel line). Sure, you
might see a slightly different fade rate, or the new paint may be a little
shinier than the old, but using the old eyeball match with rattle can paint
will leave you with a functional but *probably* ugly repair.
Depending on where you live, there may be someone who specializes in "on
airport" spot painting. I live in Atlanta, and have a buddy who makes good
money doing touch-up work on aircraft. He has a trailer with all of the
necessary equipment, paint, and pigments for color matching. He'll simply
drive to the airport, string some plastic around your airplane, mask, prep,
and spray small areas.
KB
Instrument Panel Paint [email protected] Owning 0 May 1st 05 02:54 PM
Trailer paint removal Chris Davison Soaring 13 September 3rd 04 10:42 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
Choice of Paint for use over Copper foil Antennas Charlie Precourt Home Built 1 December 2nd 03 02:51 AM
