The Yellow Triangle
Old February 17th 21, 12:56 AM posted to rec.aviation.soaring
Nicholas Kennedy
Default The Yellow Triangle
On many German gliders on the ASI is a yellow triangle.
This Yelloe Triangle on my ASw 20 and my LS3a is the factory recommended approach airspeed. This speed is 49 knots.
This has bothered me for a long time now, I think the factory did alot of pilots a disservice by putting this, to me anyway, very low number on there.
On both the above gliders, the max speed, normal landing flap flaps down, is 86 knots.
About 15 years ago my Gold Seal flight instructor Bob Faris, CX,indicated to me in his LS3 he planned on a much higher speed in the pattern, like 70-75 knots depending on conditions. I followed suit ever since.
Old February 17th 21, 01:09 AM posted to rec.aviation.soaring
Nicholas Kennedy
This Yellow Triangle on my ASw 20 and my LS3a is the factory recommended approach airspeed. This speed is 49 knots.
About 15 years ago my Gold Seal flight instructor Bob Faris, CX ,indicated to me in his LS3 he planned on a much higher speed in the pattern, like 70 to as high as 80 knots depending on conditions. I followed suit ever since.
I read in Soaring magazine frequently pilots stating that their in the pattern around 50 knots, this makes the hair on the back of my head stand on end! There is no margin for error at these low speeds. No reserve energy at all.
Stalling and spinning in the pattern has been going on forever, generally resulting in a awful crash.
I think we should all come up with a much higher speed in the pattern, and trim for and hold that speed until about 20' off the ground, this could eliminate alot of accidents IMHO.
I know all about the theory of adding half the windspeed and all of the gust factor, never the less Airspeed is everything! As a group we have to do better in this important phase of flight.
What do you Glider Gods think?
Nick
T
Old February 17th 21, 01:51 AM posted to rec.aviation.soaring
Dan Marotta
I fly around 65-70 KIAS in the pattern in my Stemme. I slow down over
the numbers.
Dan
5J
Nick
T
Old February 17th 21, 02:04 AM posted to rec.aviation.soaring
Tango Eight
Nick
T
In my experience, the minimum approach speeds given in the POH and labelled with the yellow triangle are pretty spot on where they need to be. My ASW-20B (48 kts) was perfect. My ASW-27 (54 kts) could be 50-52. Not really a big deal. These are recommended minimums. Like any other glider pilot I have had occasion to fly much faster approaches, appropriate to conditions.. Best practices are scenario dependent.
I typically fly 65 in the pattern in a glass ship (unless I need to loiter), I choose whatever speed I need to for my approach. In light conditions, it's usually right on the yellow triangle. I fly in the land of small-ish agricultural fields. It just makes sense to be good at this.
If you want to assess your margin, put the ship in landing configuration at altitude and do a slow deceleration to full stall. You might be surprised..
T8
Old February 17th 21, 01:29 PM posted to rec.aviation.soaring
Ditto T8.
Speed chosen for the approach should be appropriate for the conditions. If the air is smooth, there is no wind, and the pilot has good airspeed control, minimum approach speed is usually pretty spot on.
There are benefits to slowing things down, making a slightly larger pattern, with a nice stabilized approach on final. Having a bit more time to set things up usually makes for a nicer approach and landing.
Of course, this is all contingent on the conditions. There is a time and place to fly 50 knots or even 80 knots; it all depends.
All the best,
Daniel
Old February 17th 21, 03:59 PM posted to rec.aviation.soaring
Dan Marotta
Well, one out of three isn't bad... Fifteen gusting well over 20 is
pretty much the norm at Moriarty, and for that reason I keep my patterns
pretty close in and plenty of airspeed. It's not at all uncommon for me
to begin my base turn abeam the threshold with IAS around 65-70. My
gear door speed is 76 KIAS.
Dan
5J
Old February 17th 21, 02:08 PM posted to rec.aviation.soaring
Hank Nixon
Nick
T
In my experience, the minimum approach speeds given in the POH and labelled with the yellow triangle are pretty spot on where they need to be. My ASW-20B (48 kts) was perfect. My ASW-27 (54 kts) could be 50-52. Not really a big deal. These are recommended minimums. Like any other glider pilot I have had occasion to fly much faster approaches, appropriate to conditions. Best practices are scenario dependent.
T8
I'm with Evan on this.
The modern ships, with more powerful brakes than the old days, and many with flaps, allow adding some margin with the ability to shed
the excess energy fairly quickly when needed. Not so much on the older ships where speed control is important.
Going into a field, all things being equal, I will be at the yellow triangle coming over the border to the field.
It is important that this be a decision and not habit because we revert to habit in stress situations and that can lead to excess energy going into a tight space.
My observation is that more ships get broken due to too much energy in field landings than too little.
Flame suit on.
UH
Old February 17th 21, 04:02 PM posted to rec.aviation.soaring
Dan Marotta
No flames here. The yellow triangle over the threshold, whatever that
may be, trees, fence, or a painted line, is a good thing, but you won't
find too many western pilots flying wide patterns at that low a speed.
I guess the point of contention here is the location where the YT speed
is attained.
Dan
5J
Nick
T
T8
Flame suit on.
UH
Old February 17th 21, 04:21 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Hank Nixon wrote on 2/17/2021 6:08 AM:
T
T8
Flame suit on.
UH
A long time ago, the Brits had the rule "it's better to hit the far hedge slowly than the near
hedge quickly". I wonder if they still find that rule useful.
Old February 17th 21, 05:47 PM posted to rec.aviation.soaring
T
T8
Flame suit on.
UH
The problem that UH has identified is the lack of training for low energy landings. I often see pilots scorching down the runway bleeding off speed so that they can arrive at the desired point. If these same pilots were forced to make an off field landing with little or no margin for extra speed the would be in serious trouble. Practice does not make perfect, but prefect practice will result in near perfect results. There is no substitute for being prepared for what can and will at some point happen.
Tales Of The Bloody Triangle [email protected] Soaring 36 March 12th 21 12:25 AM
OLC FAI triangle geometry different than FAI [email protected] Soaring 1 September 5th 15 12:41 PM
200km/hr 100km triangle Tony[_5_] Soaring 2 January 14th 15 04:05 PM
500 km Triangle at 306 km/hr in Argentina Paul Remde Soaring 36 January 3rd 07 08:48 PM
FAI triangle in SEE YOU Paul Feltz Soaring 2 July 7th 04 07:46 AM
