Experience towing a Grob-103 with a 160HP tow Plane?
Old March 16th 21, 07:40 PM posted to rec.aviation.soaring
Default Experience towing a Grob-103 with a 160HP tow Plane?
Does anyone have experience with towing a Grob 103 or similar large 2-seat glider with a tow plane in the 160 HP class. Any specific experience details, lessons learned, or recommendations are appreciated. Did you do any testing prior to conducting training? If so, what was executed and logic for a testing progression, for instance. Does anyone propose environmental limits or runway length recommendations?
Asking because our 235 HP Pawnee is going to be offline for a while and we're investigating a lesser-powered Pawnee as a stand-in.
Old March 16th 21, 09:12 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Yes, I've had a few tows at another UK club in their G.103 Acro III
behind their 150 HP Pawnee. That wasn't a lot of fun on a hot summer
afternoon in the Border country, a bit south of Edinburgh, because the
climb rate was almost nonexistent until the Pawnee eventually picked up a
few knots and was able to climb away, but still quite slowly. The G.103
got off ground in a reasonable distance, but I'd be surprised if we were
at more than 100 ft as we crossed the airfield boundary. Put it this way:
the ground looked closer than I liked for the next minute or two. This
was operating off a large, grass airfield, used for training RAF Typhoon
(heavy fighter) pilots in WW2. On that first visit my first flight was an
introduction to show me the airfield and surroundings, so we were flying
two-up, neither of us being heavy pilots. I got to fly the G.103 again,
this time solo, in the late afternoon.
I subsequently took my Libelle back to the same airfield another couple
of times, both in late October with cooler autumnal air getting quite
cold early to mid morning or late afternoon. On those trips that Pawnee
was able to do quite a bit better with the G.103 (flown two-up for
intrucuctory flights looking for wave and being shown the routes to and
from the local hill. Needless to say that Pawnee was a lot more sprightly
with my Libelle on the back.
I hope the above is useful info.
I think the only slower aero tow I've experienced was two-up in a Duo
behind a 160 hp SuperCub at Wiener Neustadt, the huge grass Austrian
airfield to the south of Vienna. In that case I wouldn't care to say
which aircraft left the ground first - only that the run seemed rather
long!
Martin | martin at
Gregorie | gregorie dot org
Old March 16th 21, 09:45 PM posted to rec.aviation.soaring
40m (130 ft) AMSL (altitude from GE).
Martin | martin at
Old March 16th 21, 09:17 PM posted to rec.aviation.soaring
Hank Nixon
We tow our ASK-21 with our 160 Super Cub. We pull it back a bit more that when we pull with our 180 Pawnee. Both do well enough to be safe.
UH
Old March 16th 21, 09:21 PM posted to rec.aviation.soaring
For many years my last club regularly towed our 103 with a 150hp Super Cub without issues. Grass strip, not particularly long but no obstructions at either end. We only had to watch when the field was soft. That said, the climb out off the end of the runway was not very impressive. Good tow pilots learn to use finesse when hp is lacking. Things like lifting one wheel first to pick up speed, staying in ground effect as you accelerate and sometimes using flaps momentarily to pop the towplane off the ground when it just doesn’t want to break free!
My current club uses a 150 hp Citabria pulling at most a Puchacz (lighter than a 103) and a Perkoz. Again, no issues for the most part but marginal when the field is soft. I’ve done plenty of towing at both clubs and I would say the Super Cub does more with 150hp than the identically-powered Citabria so it is not just hp that matters.
As for tow pilot training in these circumstances, you just have to make sure the pilot is comfortable with his/her abilities. I have to admit that we have continued many tows on faith believing that we would eventually get off and clear the bushes or fences simply because we have always managed to do so. Any pilot flying by the numbers would in many cases have abandoned some of the tows we do! That said, we’re looking for a new towplane with more hp!
Old March 16th 21, 09:37 PM posted to rec.aviation.soaring
Mark Mocho
When giving these examples, you should include field altitude and density altitude to give us an idea of what was actually happening. At out field elevation (6,200 MSL) and a density altitude often over 9,000 in the summer, I suspect a 160 HP towplane with two occupants in a G-103 would only be doing taxi tests.
Old March 17th 21, 12:28 AM posted to rec.aviation.soaring
I have made several hundred tows in the 180 hp Pawnee with a 103 and ASK21, no problem! If I had my choice the 180 hp Pawnee would be my favorite.
Old March 17th 21, 12:44 AM posted to rec.aviation.soaring
Dan Marotta
Decades ago, I towed all comers, including G-103, Twin Astir, and Blanik
with a 180 hp Super Cub and a 180 hp Citabria at Black Forest, elevation
7,050 and with density altitudes aroun 10,000'. We had a 3,400' runway
with a fence at the end of the normal direction. IIRC, it rarely took
more than half of the runway.
Dan
5J
Old March 17th 21, 03:26 AM posted to rec.aviation.soaring
Good point. 1500’ MSL.
Old March 17th 21, 04:30 AM posted to rec.aviation.soaring
Roy E
We tried it once about twenty ears ago with our 150 hp Cessna 150, on a 2500 ft long grass strip at 1900' asl at about 70 degF with a light breeze. The tug had gained about 1 foot of altitude at the end of the runway. To shorten the agony on tow, the glider released below 2,000 ft agl. Our chief tow pilot took a long rest after that tow. We never tried it again.
We still have the Cessna 150/150 and perform 2,000 ft tows with our L23 in about 10 to 12 minutes, start to stop. Our club has ruled out the purchase of a Grob 103, because of the memory of that one tow.
Roy
Tow plane types/mods for high density altitude glider towing son_of_flubber Soaring 50 August 27th 19 09:15 PM
I bought X-Plane and I want to share my experience Bruce Shankle Simulators 2 July 21st 03 10:33 PM
Has Anyone had experience with X-Plane? John Westerlage Simulators 2 July 21st 03 10:02 PM
I just bought X-Plane and want to share my experience Bruce Shankle Home Built 2 July 21st 03 05:48 PM
I bought X-Plane and I want to share my experience Bruce Shankle Products 0 July 21st 03 08:25 AM
