Glider for heavy Pilot
Old March 21st 21, 01:55 PM posted to rec.aviation.soaring
Hank Nixon
Default Glider for heavy Pilot
We are looking at what gliders may be suitable for heavy pilots. Gross weight, max mass of non lifting components, and forward CG limits. Subject pilot weighs 280 lb.
Ant experience out there?
Thx
UH
Old March 21st 21, 02:16 PM posted to rec.aviation.soaring
Ed Gaddy[_3_]
Thx
UH
SGS 2-23, Front seat maybe, rear seat dual for sure.
Old March 21st 21, 02:17 PM posted to rec.aviation.soaring
Ed Gaddy[_3_]
Thx
UH
Make that a 2-32
Old March 21st 21, 07:32 PM posted to rec.aviation.soaring
Chris Behm
Thx
UH
UH-
I have been wondering if anyone in the past has modified a dual seat glider into a single seat for heavy pilots.
I would think it would be possible and an option, although getting it done and approved might be a bigger problem.
Doing this to a high performance 2 seat glider seems like it would be an attractive option for large and heavy glider pilots.
Regards,
Chris Behm
Old March 21st 21, 09:09 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Thx UH
UH-
Bear in mind that many (most) German gliders design straps and their
mount point requirements to match the maximum per-seat load, so adapting
a dual seat glider for a 200kg pilot would need cockpit structural
changes to (roughly double the max load on straps and their attachment
points as well as seating position changes to keep the CG within limits.
All in all, it sounds to me like a job needing the expertise of Bob K or
the Streifeneder team at Glasfaser.
Martin | martin at
Gregorie | gregorie dot org
Old March 22nd 21, 12:04 AM posted to rec.aviation.soaring
Nicholas Kennedy
280 is alot
Would a Grob Speed Astir or one of the Grob single seat models work?
My Grob Twin Astir had large seats....
Nick
T
Old March 22nd 21, 05:17 AM posted to rec.aviation.soaring
Frank Whiteley
On Sunday, March 21, 2021 at 6:04:26 PM UTC-6, wrote:
280 is alot
Nick
T
There are a few that would be within CG range, but very few that would allow that margin with non-lifting parts. Genesis 2 could probably be 'weighted' to work using the rear ballast weights and may still be in the non-lifting parts range. IIRC, Open Cirrus CG range is good to about 350lbs, but it would exceed the seat weight restraint limit of 242lbs, yet still be within the max dry weight and non-lifting parts range (551lbs) of 882lbs. BGA allows a LAK12 to put lead in the tail to allow 130kg in the cockpit, but the cockpit may be tight in other dimensions.
Frank
Old March 22nd 21, 08:29 AM posted to rec.aviation.soaring
I have flown a twin astir at max front seat weight ,
You run out of back stick to get speed down ,
NOT a glider to fly over max weight ,you run out of elevator
Gary
On Monday, March 22, 2021 at 1:04:26 PM UTC+13, wrote:
280 is alot
Nick
T
Old March 22nd 21, 04:26 AM posted to rec.aviation.soaring
JAB
On Sun, 21 Mar 2021 06:55:22 -0700 (PDT), Hank Nixon
ASK21B - 286 lbs with parachute...Front seat single seated
Heavy pilot - what glider to opt for? [email protected] Soaring 53 April 7th 14 04:38 PM
Hangar dolly for heavy glider Dave Nadler Soaring 20 May 29th 13 05:49 PM
Glider pilot and ME 163 Komet Pilot Rudy Opitz Has Died Paul Remde Soaring 5 May 12th 10 12:56 AM
ETA glider landing with heavy front wind in Rieti, videoclip PCool Soaring 2 October 1st 09 03:10 PM
Heavy pilot & lead in tail Flyhighdave Soaring 8 January 4th 04 01:28 AM
