IGC Flight Recorders - Updates for Filser, LXNAV, LX Navigation andNielsen Kellerman
Old March 25th 21, 09:21 AM posted to rec.aviation.soaring
Ian Strachan[_4_]
Default IGC Flight Recorders - Updates for Filser, LXNAV, LX Navigation andNielsen Kellerman
IGC FR Updates published on 24 March are as follows:
(1) Updated LXNAV LX8000 approval, adding the LX8030 and LX8040 variants with larger screens.
(2) Additions to approvals for LX Navigation LX20/21. DX50, and LX5000 with references to pre-2008 FRs under the Filser name.
(3) Lines for Filser and Nielsen Kellerman added to table of FR Manufacturers.
There are now 60 main types of IGC-approved Flight Recorders, and the number increases to 76 when different models within main types are added.
The main table of all IGC-approvals and individual IGC-approval documents can be downloaded from either the GFAC or FAI/IGC web sites, see below, together with other information on IGC-approved Flight Recorders.
More detail is in the notes that follow.
Ian Strachan
Chairman, IGC GNSS Flight Recorder Approval Committee (GFAC)
www.ukiws.uk/GFAC
Notes: 1. For the GFAC web site, see: www.ukiws.uk/GFAC
the complete table can be viewed directly at:
www.ukiws.uk/GFAC/igc_approved_frs.pdf
The table lists the name and main characteristics of individual IGC-approvals and in the last column there is a link to individual documents; click the link to call up the document. The table is followed by a list of individual IGC-approval documents in alphabetical order of manufacturer’s name from Aircotec to Zander. These can be called up by clicking the document name.
2. For the FAI/IGC web site go to: www.fai.org/igc-documents
Scroll down and click "Flight Recorders",
look down and click on: "IGC-approved Flight Recorders - Approval Documents"
then click on "IGC-approval Documents for all IGC-approved Flight Recorders"
This will call up a list of documents, the first one being:
"igcapproval_table_history_-_date.pdf"
followed by FR manufacturers in alphabetical order from Aircotec to Zander
If you own or fly with one of these FRs, it is recommended that you download its latest IGC-approval document from one of the web sites given above, and note any changes that may affect how you operate it.
The document with the table of IGC-approvals contains a number of other items, as listed below:
(1) A table of all types of IGC-approved Flight Recorders in alphabetical order of manufacturer name, with links to their IGC-approval documents in the right hand column under "Date of Latest Document".
(2) A table of Manufacturers of IGC-approved Flight Recorders, in alphabetical order of name.
(3) A diary of all IGC-approval activity from the first IGC-approvals in 1996 to the present day, recent events first.
(4) A history of GNSS Flight Recording in IGC together with pictures of some early Recorders.
Updates to the Specification for IGC Flight Recorders and Annex B tothe Sporting Code Ian Strachan Soaring 0 September 8th 19 06:39 PM
IGC-approval for LX Navigation Eos and Era series of Flight Recorders Ian Strachan[_3_] Soaring 0 April 15th 18 05:54 PM
IGC approval for S-10 and S-100 Flight Recorders made by LXNAV Ian Strachan Soaring 0 April 29th 16 07:49 AM
IGC-approval update for Flight Recorders - LX Navigation Colibrimodels 1 & 4 Ian Strachan Soaring 0 November 9th 12 12:31 PM
Updates to IGC approval documents for GNSS flight recorders Ian Strachan Soaring 2 September 27th 04 02:32 PM
