FS2002 Throttle Problem
Old May 23rd 05, 05:41 PM
Steve
Default FS2002 Throttle Problem
Does anybody have a "Fix" for the FS2002 Throttle?
I have a CH Products Yoke with 3 levers (USB).
I want to use one of the 3 levers to control the throttle settings.
When programmed into the FS2002, the throttle lever works to some
extent.
When the throttle level on the yoke is fully applied (Full Throttle), the
SIMs throttle indicates only 3/4 full, amounting to only 2300 RPM.
To increase the throttle to full RPM (about 2500) I need to use the
mouse pointer to click and drag hte throttle icon.
Also the opposit is true. If I pull the throttle all the way back (on yoke),
the SIM indicates 1000 RPM. To get it lower, I need to click and drag
the mouse pointer again to bring the RPM to idle.
Any help would be greatly appreciated.
Steve S.
Old May 23rd 05, 09:47 PM
Tom Gibson
Hi,
Sounds like you need to calibrate it. Options/Controls/Calibrate.
Hope this helps,
extent.
Steve S.
Tom Gibson
Cal Classic Propliners www.calclassic.com
FS2002 AI landing problem in Fiji [email protected] Simulators 1 November 23rd 04 01:29 PM
Another Cirrus BRS deployment: Dan Luke Piloting 111 April 19th 04 04:34 AM
Seat height problem Slav Inger Piloting 7 July 22nd 03 02:31 PM
fatal bird strike StellaStar Piloting 9 July 13th 03 09:41 PM
Rotax 912 Full Throttle Springs Mark Callahan Home Built 0 July 5th 03 01:31 PM
