Schweizer towhook inversion
Old April 3rd 21, 05:25 PM posted to rec.aviation.soaring
Andrew[_16_]
Default Schweizer towhook inversion
As suggested long ago, Schweizer towhooks may be difficult to operate in the event of a kiting incident, and are much safer if installed upside down. I have found a copy of an FAA approval (form 337) for doing this on a Pawnee. If anyone still wishes to do this modification, having this prior 337 approval will probably make getting FAA approval for the modification easier.
The 337 form, along with backup documentation, is at the following dropbox link:
https://www.dropbox.com/sh/u6skt3g1q...wmcZ3Edxa?dl=0
Old April 4th 21, 07:23 PM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Good information and congrats for making it available. While one might be in the process to at least invert the hook I would strongly recommend making the release handle available to the pilot while seated in the upright and strapped in position. Not all kiting events are slowly evolving, some are violent and instantaneous and diving for the floor can be quite challenging under such conditions. I would also strongly suggest increasing the mechanical advantage of the handle above the recommended 5 - 1 ratio recommended by the FAA.
Walt Connelly
Former Tow Pilot
Now Happy helicopter Pilot
Old April 6th 21, 06:39 PM posted to rec.aviation.soaring
Tony[_7_]
On Saturday, April 3, 2021 at 12:25:29 PM UTC-4, Andrew wrote:
As suggested long ago, Schweizer towhooks may be difficult to operate in the event of a kiting incident, and are much safer if installed upside down.. I have found a copy of an FAA approval (form 337) for doing this on a Pawnee. If anyone still wishes to do this modification, having this prior 337 approval will probably make getting FAA approval for the modification easier.
Thank you brother!
inverted Schweizer towhook [email protected] Soaring 40 October 4th 20 03:03 AM
STC for C-172 towhook Tom K (ES) Soaring 4 July 31st 13 01:52 AM
Pawnee towhook for a tie down? [email protected] Soaring 0 September 27th 07 02:34 AM
FS: Schweizer 1-34, Schweizer Open Trailer F.L. Whiteley Soaring 2 April 10th 04 02:52 AM
Cessna towhook Bob C Soaring 0 January 23rd 04 02:34 AM
