Vc gear fixed!
Old April 6th 21, 09:39 PM posted to rec.aviation.soaring
Phoenix
Default Vc gear fixed!
I would like to thank everyone who made suggestions regarding the difficulty in both raising and lowering the gear on my Ventus C.
Turns out the culprit was the castle nut on the axel was way too tight. I loosened it to only hand tight and installed a new pip pin (sp?) Works like it was designed to do.
Again - thanks for all the suggestions.
Old April 7th 21, 02:34 AM posted to rec.aviation.soaring
Mark Mocho
"Pip pin" is correct. "Axel" is not. An "axle" is a shaft used to locate and contain a rotating mechanism.
An "axel" is a jump in skating with a forward takeoff from the forward outside edge of one skate to the backward outside edge of the other, with one and a half turns in the air.
And you probably installed a cotter pin, not a pip pin.
Just sayin'
Old April 7th 21, 06:30 PM posted to rec.aviation.soaring
john firth
Just sayin'
Next time on the ice , will try that; this must be the root of the word axeleration,
meaning speeding up rotation.
JMF
Old April 7th 21, 07:37 PM posted to rec.aviation.soaring
Mark Mocho
Acceleration, exhilaration, exceleration (nonexistent word), who cares. People will use them interchangeably.
Like: to, too, two, there, their, they're, lose, loose, your, you're, bow (in it's many pronunciations and definitions) and so on.
And I won't even start on the poor misguided apostrophe. Let's just say that some parts of the country must be suffering a shortage, since so many extras are being misused in Moriarty.
Old April 7th 21, 09:58 PM posted to rec.aviation.soaring
Dan Marotta
Moriarty... Isn't that where the tooth brush was invented?
Dan
5J
Old April 8th 21, 07:20 PM posted to rec.aviation.soaring
Dave Nadler
Thanks to John May for suggesting the correct fix,
and also to Phoenix for confirming it to the group.
Lockheed Model 12 Electra Junior pics [7/7] - U.S. Army Air Corps C-40B with fixed tricycle landing gear.jpg (1/1) Miloch Aviation Photos 0 May 21st 20 06:48 AM
MiG-31 mig-31-fixed.jpg 139 (1/1) J3[_2_] Aviation Photos 0 February 27th 20 01:25 AM
de Havilland Canada DHC-1 Chipmunk pics 2 [3/4] - Super Chipmunk (fixed gear).jpg (1/1) Miloch Aviation Photos 0 August 17th 18 02:59 PM
Fixed it Jim Morris[_4_] Aviation Photos 11 July 7th 08 09:43 AM
Mooney Acclaim vs. Columbia 350/400 (which has fixed landing gear??) Justin Gombos Piloting 22 June 18th 07 12:03 PM
