How Do You Evaluate an OLC Flight ?
Old April 24th 21, 11:29 PM posted to rec.aviation.soaring
Default How Do You Evaluate an OLC Flight ?
I would like to know how others evaluate an OLC flight and determine the difficulty factor involved? I will hold my opinion until this has been truly debated. Old Bob
Old April 25th 21, 06:47 PM posted to rec.aviation.soaring
Tony[_7_]
The file may have a declaration embedded, but I suppose you would have to download it to read it. Other than that, there's no comparison with committing to a task. Of course there's much to be said for skillful task-setting!
Old April 26th 21, 08:01 PM posted to rec.aviation.soaring
Jason Leonard
sub'd
Old April 27th 21, 12:07 AM posted to rec.aviation.soaring
Matthew Scutter
You won't believe it Bob, but the OLC does it for you and allocates points accordingly!
Old April 27th 21, 12:11 AM posted to rec.aviation.soaring
Matt, it must be a conspiracy! The question was how do you, not OLC, it flew right over your head.
Old April 27th 21, 10:42 PM posted to rec.aviation.soaring
Mike the Strike
Some years ago, OLC added bonus points for triangle flights after analyzing many cross-country flights - adding about 30% in points as I recall. Before that, points were based solely on distance and glider handicap.
This is a pretty rough guesstimate of evaluation - distance plus triangle bonus - but there are plenty of other variables left out.
Feel free to develop a new set of algorithms!
Old April 28th 21, 07:56 PM posted to rec.aviation.soaring
Mike, you are on the correct path. Old Bob
Old April 28th 21, 09:29 PM posted to rec.aviation.soaring
5Z
The folks at WeGlide.org appear to be open to scoring formula and data presentation suggestions. I just asked them to somehow identify declared fights. These are often more difficult that an ad-hoc choice once in the air.
5Z
Old April 28th 21, 09:30 PM posted to rec.aviation.soaring
Tony[_5_]
I usually look at the circling % to analyze how difficult a particular flight was.
Old April 28th 21, 10:36 PM posted to rec.aviation.soaring
Moshe Braner
5Z
- Good idea. If there is a declaration within the flight log file (as
is now required (in the USA) rather than on paper), it is possible for
the software to check whether the declared task was completed. SeeYou
does that. A fine point is that the rules for crossing the start and
finish lines and rounding the turnpoints may differ between countries.
Remaining questions include:
* how many more points to award for completion of a declared task
* or perhaps just display the fact that it was a declared task - seems
like what you asked for
* what to do with partially-completed tasks, do they deserve any extra
points (or recognition) relative to flights with no declaration
* what to do with additional distance flown beyond the declared task
EA-6b a-flight-crew-sits-in-the-cockpit-of-an-ea-6b-prowler-aircraft-on-the-flight-e63638-1600.jpg 803 (1/1) J3[_2_] Aviation Photos 0 July 5th 19 08:28 PM
IGC Flight Recorders using Flarm firmware - New DLL file forvalidating IGC flight data files Ian Strachan Soaring 0 July 20th 14 07:28 PM
Army to evaluate existing airframes for Kiowa Replacement. vaughn[_3_] Piloting 4 October 14th 11 06:30 AM
Army to evaluate existing airframes for Kiowa Replacement. VOR-DME[_4_] Piloting 0 October 13th 11 05:36 PM
How to evaluate a respirator? Qualities? mhorowit Home Built 6 May 28th 06 07:27 PM
