Multiple Monitors on FS2002
Old May 26th 05, 02:43 AM
Steve
Default Multiple Monitors on FS2002
How can I hook-up 3 monitors to my FM 2002?
I would like to use one for the instr. panel and the other
2 for left and right window scenery.
Thanks in advance.
Steve S.
Old May 26th 05, 04:27 PM
Otm Shank
First you need a video graphics card that can support multiple monitors.
Otm S.
Thanks in advance.
Steve S.
Old May 26th 05, 05:42 PM
GEG
Here's how I did it:
I have a Matrox AGP slot video card that supports 2 monitors.
I then bough a PCI Matrox card that supports 2 monitors.
Generally - I've found that you should have the same brand of
video cards.
I have 4-monitor capability.
It's generally cheaper to have 2 video cards than a single card
that has 3 or 4 outputs, as they run a premium.
Even if you have a single AGP video card, you can get something for
under $100 at BestBuy or CompUSA that is a PCI slot dual output monitor.
When setting up the sim, I go out of "full screen mode", go to each
window and define the view (for example, rotating left or right to get
side views), then go back to full-screen mode.
There are some on line articles that describe it - I had to find
them through search engines.
Hope that helps.
Gary
FS 2004 with multiple monitors - how to save settings? Horst Walter Simulators 5 December 8th 04 01:29 PM
fs2002 problem Roger Maskell Simulators 9 June 17th 04 11:14 AM
FS2002 Compass Anomaly - PLEASE HELP GM EWA Simulators 0 January 13th 04 11:20 PM
FS 2002 Multiple Monitors Hugh Roberton Simulators 1 September 22nd 03 01:49 PM
Help needed - fs2004 zaps fs2002 props Ian D Simulators 1 September 11th 03 10:20 PM
