MS/FS Netpipes SDK ObjectID question
Old May 28th 05, 12:36 AM
Default MS/FS Netpipes SDK ObjectID question
Hello, my goal is to drive microsoft flight sim using an external data
source. I read the netpipes SDK and am in the process of creating the
binary conversion program from my data source to the "flight video"
..fsr format. I have questions about the section regarding the
"ObjectID" field in the "OBID" data section. According to the SDK:
"The object ID is an ID for a class of objects. Specific instances of
the object will be given a compound ID created from two keys. The
object ID will be in the upper 4 bits of the word, and the lower 12
bits will be the instance ID. Because of this arrangement, the object
ID in the Object Definition must be provided under the mask 0xf000. The
lower 12 bits of this field MUST be 0 in this record."
3 questions arise from this. First, it's my assumption that this
objectID has a direct relationship to a single plane i.e. the one
you're flying. Am I correct?
Second, if my first assumption is true then that means that there are
only 4 bits or 16 unique IDs available. Meaning that there can only be
16 planes (15 surrounding + the one you're flying) that can be
recorded/played back in the flight video. This seems small but then
again, 16 planes in your field of view is a lot I guess. Again, is
this a correct assumption?
Third, I haven't worked with bitwise operations in a while. How do I
get my identifying bits to the left-most 4 bit positions? i.e. WORD
objectID = 12; would have the following bit positions:
0000000000001100
Since I need to use only the left-most 4 bit positions for my objectID,
then I need to somehow move the rightmost 4 bits to the opposite side.
How do I do this in c++?
Thanks for any help/pointers anyone can provide. If I'm in the wrong
group for this, please _kindly_ point me to the correct group.
Old May 31st 05, 10:08 PM
I'm still waiting for the answer to the first 2 questions. I found the
answer to the third question.
"var = 12" will shift the bits to the left 12 times which will move
the right-most 4 bits to to the left-most 4 bits.
Old May 31st 05, 10:48 PM
Quilljar
An email to Bill Leaming
might produce results. Worth a try, he's a bit of an expert on these
things...
Quilljar
see
http://client.webshots.com/album/194691959rhDQFi
Do not reply personally, all such emails go into my spam filter
Old May 31st 05, 11:27 PM
sorry, google groups removes e-mail addresses so I can't see it .
Any chance you can send me an email with it?
Old June 2nd 05, 03:43 PM
Quilljar
Have done.
Quilljar
see
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 12:14 AM
